Show us your unique bike mod!
Re: Show us your unique bike mod!
08 Aug 2020 17:51
Billet Lower Triple tree by Les Holt at PDM
and Kosman steering dampner mounts for dual dampners
Notice how the brake splitter is machined into the tree
08 Aug 2020 17:54Original owner 78 1000 LTD
- Sheath
09 Aug 2020 08:51
Nice
and the machined in brake splitter is very neat too
- loudhvx
09 Aug 2020 14:58
I must now reassemble my mind after seeing the brake-splitter triple tree. That's awesome.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- Warren3200gt
09 Aug 2020 15:54H1's came from the factory with that splitter set up. Not sure about H2's. Anyone?loudhvx wrote: I must now reassemble my mind after seeing the brake-splitter triple tree. That's awesome.
- Dr. Gamma
09 Aug 2020 16:12
H2'S were just like the Z1 setup.
Now the '73 S2 350 triple and the '74 and '75 S3 400 triples both had the brake fluid in the lower triple tree.
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: loudhvx, Warren3200gt
- Dr. Gamma
09 Aug 2020 16:45 - 09 Aug 2020 16:47
Here is the story about the modifications done to the swing arm and the swing arm pivot bolt. Way back in 1978 when I started building my Superbike, the rules stated you had to use a stock swing arm with out any additional bracing. Well what most of the top teams were doing was cutting open the swing arm and welding in some internal bracing then weld the swing back together. The only thing that gave it away was the two welds that ran the length of the arm!!!! That is what Pierre DesRoches did to my swing arm. Then in 1980 they allowed you to brace the swing arms. I added the lower hoop and bracing to my swing arm. I used some thick wall 4130 tubing on mine.
The biggest improvement to my swing arm was going to an oversize pivot bolt to eliminate the excessive clearance between the pivot bolt and its mounting bosses on the frame. The factory clearance is anywhere from .020 to over .040 thousands!!!! You want ZERO clearance there and also between the inner sleeve and the pivot bolt. I had just over .022 thousands between the frame and the pivot bolt. So I had my machine shop make up some oversize pivot bolts. Then I used an expandable reamer to open up the frame to fit the oversize pivot bolts. Then had the inner swing arm sleeve honed to fit the new oversize swing arm bolt. This setup eliminated any side to side play in my swing arm. I have to tap my swing arm bolt into place. The only giveaway of all this work is the fancy aircraft nut on the end of my oversize bolt!!!! I picked up doing this by the same fancy aircraft nut on the factory Kawasaki Superbike and the Yoshimura Superbikes!!!! When I asked the only English speaking Yoshimura mechanic about it. His reply was "You got good eyes to pick up on that"
This is the only thing that gives away the oversize swing bolt.
Last edit: 09 Aug 2020 16:47 by Dr. Gamma.
The following user(s) said Thank You: DOHC, ghostdive
- bluej58
09 Aug 2020 17:33
Hey Doc, please show them what you do with the stock cam plugs.
78 KZ1000 A2A
- Dr. Gamma
09 Aug 2020 17:56bluej58 wrote: Hey Doc, please show them what you do with the stock cam plugs.
If you install the O.E.M. cam plugs backwards, they have that outer lip toward the inside. Its almost impossible for the cam plugs to pop out of place.
I think they showed us this trick at Kawasaki Service School!!!!
The following user(s) said Thank You: bluej58, Mikaw
- KZJOE900
- Administrator
Super Users
10 Aug 2020 15:46
My home made fender eliminator. I used portions off of the old fender. My old fender was cracked. I had it welded but still didn't look good. So I used my cutting tool to cut back the fender past the crack and reinstalled it as shown. You can also see the back of the home made bracket I made ( flat aluminum bar which I hand formed with a hammer ) to hold the tail light.
Under the seat, it still seems like the fender is still there.
You can see the end of the bracket holding the light. I decided I liked it sticking out a bit. I also mounted the original license plate holder from the old fender as part of the assembly. Used hardened bolts in place of the original mounting bolts at the back of the fin.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- KZJOE900
- Administrator
Super Users
10 Aug 2020 15:54 - 10 Aug 2020 15:55
My handy dandy carb support mod. Not that I ever had issue or ever heard of problems with the manifolds keeping the carbs secure. But after some jolts on a couple of rides on these country roads, I decided to give them some support. It is not actually attached to the carbs and they only sit on there via carb no. two. But there is no play for the carbs to move.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 10 Aug 2020 15:55 by KZJOE900.
- tomsbadkz
11 Aug 2020 06:17
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
