Front disc brakes
  • Klida
  • Klida's Avatar Topic Author
Front disc brakes
18 Apr 2020 19:09
#823630
I have a 1977 Kawasaki KZ 1000 LTD B1. I rebuilt both front calipers and master cylinder. And replaced all the front lines with stainless. Installed everything and bleed the lines. Front wheel can barely move. I think the pistons are hung up or master cylinder is shot. But not really sure . Can anybody tell me some insight or what my next move is?
  • CCrosswait
  • CCrosswait's Avatar
Re: Front disc brakes
18 Apr 2020 19:58
#823635
Did you confirm the small orifice in the mast cylinder was clean and clear?
2019 Indian FTR1200S
2018 Triumph Rocket 3
1981 Kawasaki KZ1100A1
1977 Yamaha RD400
1980 Honda Express II
  • TexasKZ
  • TexasKZ's Avatar
18 Apr 2020 20:00
#823636
In the master cylinder, there are two holes between the cylinder and the reservoir. On is obvious, and one is really tiny and easily clogged and easy to overlook. If it is clogged, pressure cannot be released from the line.
  • hardrockminer
  • hardrockminer's Avatar
18 Apr 2020 20:47
#823641
Did you check the inside groove in the cylinder? They should be carefully cleaned before inserting the seal that wraps around the piston. This seal is what makes the piston back off a bit when you release the brake handle.
