Throttle Cable Headache
- mgutjr
14 Sep 2019 10:41
Hey y'all,
My OG throttle cables (54012-141, 54012-140) are kinked and sticking, so I figured I'd replace them with two new ones from Z1 Enterprises: 03-0001. On their site it states that the 03-0001s are equivalent to the 54012s, but the Z1 parts are clearly 1/2" longer. The 54012s are 43.5" from end to end on the outside, while the 03-0001s are 44" end to end on the outside. Any thoughts on this? My bars are stock, so I don't think that should be an issue. Thanks!
1977 KZ650B
1977 KZ650B
Re: Throttle Cable Headache
14 Sep 2019 12:50 - 14 Sep 2019 12:55
I've owned my 1977 KZ650-C1 since it was new, and I only use genuine Kawasaki cables on it. Properly lubed and installed they should last pretty much forever with zero problems. The only reason I replaced mine (once in more than 42 years) was for aesthetic reasons since finish on the top connectors was looking rather old. You already know the correct part numbers, so why not just buy the real deal? You should be able to find them easily on eBay. BTW, if yours were kinked they definitely were not installed correctly, throttle cable should operate very smoothly. Ed
Last edit: 14 Sep 2019 12:55 by 650ed.
- ThatGPzGuy
16 Sep 2019 16:44
I just had to replace my throttle cable on the '82 GPz. It was sticking and not letting the idle remain stable. I found an NOS OEM cable on eBay for $15.
I made sure to follow Ed's advice and lube the new one well before install. And, on a positive note I was able to get the new cable in without taking the carbs out. Works great now.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
