1977 KZ650B Manual Petcock Replacement?
  • mgutjr
  • mgutjr's Avatar Topic Author
19 Aug 2019 17:59
#809506
Anyone know of a good replacement for this petcock? Ideally a manual petcock. I don't want a vacuum petcock.
I've rebuilt it the current one. Replaced the O-rings and it still leaks. I just need a new one.
Thoughts?
  • martin_csr
  • martin_csr's Avatar
Re: 1977 KZ650B Manual Petcock Replacement?
20 Aug 2019 10:11 - 20 Aug 2019 10:25
#809555
Your bolt-hole spacing should be 44mm center-to-center. Someone on another forum put an oem Yamaha Raptor manual fuel valve on his Zephyr 550 & I think the Zephyr is 44mm. not 100% sure, though. The Yamaha fuel cocks vary in shape & the way they fit under the tank >> some of them are squat & would be tucked tight against the tank, while others hang down more.
The Yamaha Raptor fuel cocks are made in Japan & affordable. Be sure to verify the bolt-hole spacing beforehand.
note: some of the Yamaha fuel valves are 34mm.
Last edit: 20 Aug 2019 10:25 by martin_csr.
The following user(s) said Thank You: mgutjr
  • Schultzboy
  • Schultzboy's Avatar
09 Sep 2019 13:06
#810591
I'm in the same boat here. I did manage to get mine apart, cleaned all the gunk out, etc. It doesn't leak, but man is it hard to turn. Not a great design.
I spoke to someone at Mikes XS (which I guess is related to Z1) and he said that this petcock has a 46mm bolt center when ours is 44mm.
www.mikesxs.net/yamaha-xs650-petcock-non...447-24500-02-00.html
I'm thinking that some gentle drilling of the mounting holes will make it easy to bolt this up on our bikes.
  • davido
  • davido's Avatar
09 Sep 2019 14:53
#810600
I want to do the same thing. Let me know how you solve it.
( Im using an inline tap between the petcock and the carbs. Not ideal but it works for now)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • Nessism
  • Nessism's Avatar
09 Sep 2019 17:39 - 09 Sep 2019 17:40
#810608
On the OEM parts fishe they list two petcocks for the 650B; an early version and later type. The later type looks identical to the petcock on my 750, which I was able to successfully rebuild with OEM parts. I wouldn't attempt a rebuild unless OEM parts are available, and there doesn't seem to be any of the early petcock rebuild parts anymore. At any rate, just sharing my experiences.
[img
P1010520 by nessism , on Flickr
Last edit: 09 Sep 2019 17:40 by Nessism.
  • mgutjr
09 Sep 2019 20:12
#810614
I ended up buying this plate:
www.z1enterprises.com/pingel-petcock-ada...CsbWeVRoCPz8QAvD_BwE
and used this petcock (bought it on Amazon):
Bikers Choice Early Style Petcock 011409
I had to dremel the hole on the tank where the petcock enters (not the screw holes), but it all fit perfectly and i haven't had a leak from the gas tank or the carbs since.
