Tire bead locks
  • Iccfl4u
  • Iccfl4u's Avatar Topic Author
Tire bead locks
15 Aug 2019 17:57
#809234
U couldn't find her right place to ask a tire question. I have a 1978 kz1000 and I was told I need bead locks?
1 is this true
2 any ideas where online to find them?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Tire bead locks
15 Aug 2019 18:12
#809237
bead locks = rubber parts bolt on the rim that lock down the tire on the rim on high acceleration. They should protect the air tube valve sheard off by rotating the tire on the rim. I am right ? If so no Need on a modern tyre any more.
The following user(s) said Thank You: Iccfl4u
  • TexasKZ
  • TexasKZ's Avatar
Re: Tire bead locks
15 Aug 2019 19:10
#809240
Number 32 on the parts diagram. Fits several models.
www.partzilla.com/catalog/kawasaki/motor...tire-hub-chain-78-d1
  • martin_csr
  • martin_csr's Avatar
Re: Tire bead locks
16 Aug 2019 05:16 - 16 Aug 2019 05:27
#809249
The stock wheels are probably tube-type (not tubeless), so you probably need to install tubes.
Whether or not a modern tire can't spin on a TT wheel & shear off the tube's valve stem under heavy throttle, I don't know.
Last edit: 16 Aug 2019 05:27 by martin_csr.
  • baldy110
  • baldy110's Avatar
Re: Tire bead locks
16 Aug 2019 09:57
#809260
No need for bead locks on a streetbike.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Tire bead locks
16 Aug 2019 10:08
#809261
I took mine out years ago. Have to use a C clamp to break the beads on my Shinko tires.
  • bluej58
  • bluej58's Avatar
Re: Tire bead locks
16 Aug 2019 18:14
#809298
I put mine back in after ripping a couple stems
78 KZ1000 A2A
