What is this worth??
- moneypit
04 Jun 2019 12:36
My son-inlaw texted me that he has a chance at a 1976 kz400 with 12000 miles all original but for mac exhaust for $400. Stored for 20+ yrs, no rust. Everything is included, airbox, side covers and carbs just not pictured. What do you think? Thanks
2-76 kz900
St Paul MN
St Paul MN
- loudhvx
Re: What is this worth??
04 Jun 2019 13:21
If the motor kicks over smoothly and feels to have compression, and there is a title, $400 is ok for now. This time of year prices are higher. Late fall, that bike would be more like $250.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
04 Jun 2019 13:30 - 04 Jun 2019 13:35
[quote="moneypit" post=805140 . . . no rust. . . .[/quote]
:huh:
Thinking I'd pass.
:huh:
Thinking I'd pass.
Last edit: 04 Jun 2019 13:35 by Patton.
- bluej58
04 Jun 2019 14:50
Split the difference and offer 350
No brake fluid to worry about, 2 tires , 2 carbs to rebuild, grease, oil, filters and some gas, that should be it.
maybe back brake pads
Nice simple project IMO
78 KZ1000 A2A
- riturbo
04 Jun 2019 15:06
I would offer less . See if he will let you do a compression test on it . Also all those dangling wires kind of make you go hmmm.. Whats up with that ? By the time you do brakes ,tires , carbs you will have a few bucks into it plus all you labor on a bike thats not worth a lot .
My two cents .
Looks like a fun project though .
My two cents .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
- moneypit
04 Jun 2019 16:37 - 04 Jun 2019 16:38
He seems to think he can get it for 300. Guy has to many projects, so its for sale. Seems thats what they all say. Son in law says it has compression. Dont know the numbers, I believe he just kicked it over. I'm 175 miles from him, so i wont see it. My guess is son in law is looking to flip it. He does that alot :dry: Any ideas what it would be worth finished as in together and running? Thanks
PS there is a clean title as well.
2-76 kz900
St Paul MN
St Paul MN
Last edit: 04 Jun 2019 16:38 by moneypit.
04 Jun 2019 20:09 - 04 Jun 2019 20:10moneypit wrote: My son-inlaw texted me that he has a chance at a 1976 kz400 with 12000 miles all original but for mac exhaust for $400. Stored for 20+ yrs, no rust. Everything is included, airbox, side covers and carbs just not pictured. What do you think? Thanks
I don't know who told you that bike is "all original" but it is not even close to being original. In addition to the exhaust that you mentioned the paint, the seat, etc. also are not original. Plus it has the drum front brake, which may be original but indicates that the bike was the least expensive model when new. Below is what the 1976 KZ400 with front drum looked like when all original. I would offer a lower price and see what the seller says. Ed
Last edit: 04 Jun 2019 20:10 by 650ed.
- loudhvx
05 Jun 2019 08:51 - 05 Jun 2019 08:59
Yes like Ed said , the drum indicates the "S" (Special) model. It would have had a 2-into-1 right side exhaust.
The puzzling thing is that the S model did not come with a tach, so did someone change the wheel or did someone change the gauge cluster.
The S model would have had no electric starter (but still has a starter cover) and a smaller battery and battery box.
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 05 Jun 2019 08:59 by loudhvx.
