Fuel Consumption KZ1000?
  • BCScott
  • BCScott's Avatar Topic Author
12 May 2019 15:24
#803731
I just did a 110 km (68 miles) ride yesterday, all 2 lane highway, averaging around 115 kph or 71 mph. I filled before and after, so used the opportunity to calculate my fuel consumption. I used 10.15 litres, so that translates to 9.2 l/100km or 30.7 imp mpg or 25.6 US mpg. Seems to me, I used to get around 40 imp mpg mixed city/highway back when I rode it in the '80s. Don't get me wrong, I don't care about the extra fuel used, even at our prices of $1.50 CDN/litre for 91 octane (US$4.23/us gal). I'm just wondering if it's symptomatic of another issue. The engine is stock with the stock airbox (newish air filter) and stock pipes and jets. I had the valves set and the carbs synked around 2,000 kms ago. Am I expecting too much of a 42 year old bike with 70,000 kms on it?
Back in the saddle and loving it! KZ1000A1
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Fuel Consumption KZ1000?
12 May 2019 15:56
#803734
Seems poor mpg
I get 25 mpg with my turbo 1000 . easily
  • bluej58
  • bluej58's Avatar
12 May 2019 16:16
#803737
I get around 40 mpg U.S. what do your plugs look like?
78 KZ1000 A2A
  • BCScott
12 May 2019 16:36
#803739
bluej58 wrote: I get around 40 mpg U.S. what do your plugs look like?
They tend to be dry and heavily carboned.
  • bluej58
  • bluej58's Avatar
12 May 2019 17:42 - 12 May 2019 17:47
#803742
You should be running 87 octane
It sounds like you are running rich, are they all even in color? maybe your choke is hanging up.
The plugs should be light brown.
78 KZ1000 A2A
Last edit: 12 May 2019 17:47 by bluej58.
The following user(s) said Thank You: BCScott
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 May 2019 17:45
#803743
I'm starting to get 40-42 MPG with my 33's. Took a lot of doing. I got 30 +/- before. You should get 40-42 dependable. Checked your timing and spark advance?
  • BCScott
12 May 2019 20:00
#803752
bluej58 wrote: You should be running 87 octane
I always used to run 87, but now with ethanol in the regular blends, I thought it would make sense to run 91, which doesn't have ethanol at my pumps. They definitely look rich, but not wet. Perhaps I should run a tank or two with 87, see if it helps and leave the 91 for winter storage. I certainly go through at least 2 tanks a week during riding season.
  • BCScott
12 May 2019 20:08
#803753
SWest wrote: I'm starting to get 40-42 MPG with my 33's. Took a lot of doing. I got 30 +/- before. You should get 40-42 dependable. Checked your timing and spark advance?
Timing I've done by eye, but not by light. It seems to run well at all ranges of throttle, so I think the spark advance is working ok.
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 May 2019 20:43
#803755
You need to check both with a light or it's not done.
  • bluej58
  • bluej58's Avatar
13 May 2019 05:04
#803771
All the 87 octane around here has ethanol , my bike runs fine on it but the gas never gets old
78 KZ1000 A2A
  • Nessism
  • Nessism's Avatar
13 May 2019 05:38
#803775
I don't know this for a fact but have read several times that ethanol laced fuel will drop mpg a little. Key word "little".
A compression check may be in order to see how the engine is fairing after all the miles. Lowish compression can result in poor mpg. Other things to check are spark quality, the air filter, and carb jets. If aftermarket carb jets were installed at some time in the bikes life the sizes may be wrong. Replacing the pilots with new Mikuni brand jets would be money well spent.
  • Oldjeep
  • Oldjeep's Avatar
13 May 2019 06:20
#803778
Nessism wrote: I don't know this for a fact but have read several times that ethanol laced fuel will drop mpg a little. Key word "little".
E10 drops your fuel mileage by about 5%. Carb operated motors need to be richened up a little bit when operating on E10. We've had E10 around here for over 25 years, never understood the whole "fuel gets old" nonsense - I store over 100 gallons of E10 per season in boats, snowmobiles, power equipment and seasonal cars. Never had a fuel related issue. Modern fuel comes with all sorts of stabilizers from the pump, so no snake oil needed.
Chuck
81 KZ750 LTD
03 FZ1
www.oldjeep.com
