Drag bars and clutch cable
  • Vincent J
  • Vincent J's Avatar Topic Author
05 May 2019 14:54
#803371
Hi guys I put a set of drag handle bars on my z1 and I'm having a issue with the clutch cable being too long.. has anyone ran into this before and possible help me find a shorter cable.. thank you Vinnie
  • martin_csr
  • martin_csr's Avatar
Re: Drag bars and clutch cable
05 May 2019 18:39 - 06 May 2019 05:51
#803380
Z1Enterprises may have the measurements of Motion Pro cables. You could disconnect the clutch cable at the lever end to figure out the overage, then mark & measure it. Then find an appropriate cable. With drag bars I'd guess a cable from a GPz model might work. of course Ltd & CSR cables are going to be way too long.
Last edit: 06 May 2019 05:51 by martin_csr.
The following user(s) said Thank You: Vincent J
  • tomsbadkz
  • tomsbadkz's Avatar
05 May 2019 20:14
#803381
I did the same thing on my KZ1000. Buy Z1R cables. I did both throttle cables and clutch cable. I think they are about 4" shorter than regular KZ1000 A model bike, not the LTD.
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
