1980 Honda speedometer question
- sharkmonkey
23 Apr 2019 23:00
Can someone answer a speedometer question?
I have a CM400T and the speedometer is jumping all over place. I replaced the cable (that was broken) and that didn't help.
So the question is, can I get a generic speedometer off of eBay and will it read accurately? Or do I have to find a specific or OEM one? I see one for an older Honda 350 that looks pretty close.
-Mark
-Mark
1983 Kawasaki KZ750 KZ1 LTD (belt)
1980 Honda CM400T
1980 Honda CM400T
Re: 1980 Honda speedometer question
24 Apr 2019 05:24 - 25 Apr 2019 05:34
Since it isn't working, I would try lubricating the speedo with a light grease, putting a little into the cable receiver orifice.
Also, try doing an internet search for CM400 jumpy speedometer, in case there's a fix. or use CB350 or CB750 etc instead of CM400.
As for a replacement speedometer, I'm pretty sure all Japanese motorcycles use the same 2240 ratio (revs per mile), so just get that type. The CM400 speedo may have the ratio stamped in ink on the back. Keep in mind that a replacement may not be the same size, so it might not fit correctly. Aftermarket are usually listed as 2240@60mph or something like that.
2240 revs = 1 mile
2240 revs = 1 mile
2240 revs = 1 mile
2240 revs = 1 mile
Last edit: 25 Apr 2019 05:34 by martin_csr.
The following user(s) said Thank You: Patton, sharkmonkey
- sharkmonkey
24 Apr 2019 16:58
Thank you, great info.
1980 Honda CM400T
1980 Honda CM400T
