VIN help
  • chefmateo
  • chefmateo's Avatar Topic Author
VIN help
09 Sep 2018 21:32 - 09 Sep 2018 21:34
#790631
New to the forum. Recently bought a 1977 KZ650...or so I thought. Bike is in great shape, runs, and seems original. However, I have conflicting numbers on my bike. The engine has KZ650BE027903 stamped on it...& the steering column behind the headlight has KZ650C003455. Obviously this bike seems to be a Franken-bike if I go by the numbers. Is there anywhere else I can look to see if one of the two numbers match another location on the bike? It's currently titled using the steering column number. I want to restore this motorcycle to original condition, so knowing what I'm dealing with will help me through this process. Any helpful info will be greatly appreciated. Thanks.
Last edit: 09 Sep 2018 21:34 by chefmateo.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: VIN help
10 Sep 2018 04:31
#790632
The frame and engine # for the KZ 650 C model
jarlef.no/Kawasaki/Series/Z/650/Z650C.htm
  • hardrockminer
  • hardrockminer's Avatar
Re: VIN help
10 Sep 2018 05:21
#790634
The frame number is used to identify the bike in most jurisdictions.
You appear to believe the frame and engine numbers should be the same. Kawasaki didn't do it that way. Frame and engine serial numbers are almost always different.
The following user(s) said Thank You: chefmateo
  • chefmateo
Re: VIN help
10 Sep 2018 05:44
#790637
I certainly did make that assumption. Thank you for clearing that up for me.
Re: VIN help
10 Sep 2018 06:32 - 10 Sep 2018 06:34
#790644
Welcome aboard! Your bike is a 1977 KZ650-C1 (so is mine). The frame number is the VIN; the engine number is not used for registering the bike. The engine serial number you posted is correct for the 1977 KZ650-C1, so your bike is not a Franken bike. The KZ engine number and VIN on the KZ650-C models never match; that's normal for the model, and your engine number falls within the correct set of engine serial numbers for the 1977-C1 bikes. Take a look at the link below. It shows the various frame numbers and engine numbers for the different year/model KZ650's. Ed
models.kz650.info/index.htm
Last edit: 10 Sep 2018 06:34 by 650ed.
  • chefmateo
Re: VIN help
10 Sep 2018 17:22
#790693
Thank you for the info & list. I do have it titled using the frame number. Now the fun part of restoration begins. I'll definitely be back to ask more questions during this process. Thankfully not a whole lot to do other than some cosmetic touch ups & some engine/carb tuning. The biggest part is cleaning up the wiring & or maybe modernization of the electrical system. She runs pretty good as is though.
