go back
- Fox
go back
01 Sep 2018 02:06
Hello,
i don't remember ///
Can we go back in rear when a gear is on ( for example when we are on the first gear) or do we must be in neutral position ?
Thank you
Thank you
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Re: go back
Yes, if all engine transmission parts and the rear wheel are moving freely but you have to pull the clutch leveler to disangage the crank and piston compression.
Have to ask, is the engine in or out of the Frame?
The following user(s) said Thank You: Fox
- Fox
Re: go back
01 Sep 2018 03:23
Put the gear leveler on and switch into neutral position.
This should be possible without pulling the clutch. A Little rocking on the output shaft/front sprocket will suppot you to go in neutral Position.
- zukdave
Re: go back
02 Sep 2018 16:43
Not sure what the ? really is but yes you should be able to pull the clutch lever in while in gear and roll it back ward's.
All of my bikes will motor running or not,
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
