my tool kit
  • Zaddict
  • Zaddict's Avatar Topic Author
  • Enjoying my Zaddiction!
my tool kit
04 Aug 2018 22:33
#788213
This kit fits nicely under the tail of my 550, along with a lithium battery jump starter/power pack (pictured).
The loose items in the top of the photo all go into the integrated zippered pouch.
I don't know, I find it relaxing assembling a kit like this (and knowing I'll be that much more prepared for maintenance and emergencies). Thought you all might appreciate it...not sure who else would!
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
  • martin_csr
  • martin_csr's Avatar
Re: my tool kit
05 Aug 2018 05:51 - 05 Aug 2018 06:09
#788220
I probably carry too much stuff. extra tools I think I might need plus the Kawaski kit under the seat. But my biggest worry is a flat tire, so I also bring along a plug kit & Slime mini-pump. If a puncture isn't too bad, hopefully I'll be able to limp home. I made up a pigtail so that I can quickly connect a 12VDC power supply to my charger adapter that's hooked to the battery.
Not shown. Ctek quick connect cable.
Last edit: 05 Aug 2018 06:09 by martin_csr.
Re: my tool kit
05 Aug 2018 06:28
#788223
I just carry the stock tool kit (shown below) plus a pack of fuses and a very small flashlight (not shown).  Everything fits in the stock tool kit pack.  Ed
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: my tool kit
05 Aug 2018 07:10 - 05 Aug 2018 09:00
#788226
We're fairly minimalist about our on-board tools.  We carry the OEM under seat tools plus a few for local joyrides.
The old Japanese OEM tools are stronger than many of today's cheap Chinese pressed tinfoil items.  The exception is the cross-slot screwdriver bits.  Good Japanese or German #1 and #2 JIS screwdrivers take the place of the soft bits in the OEM kits.
We test at home what we carry on the road to make sure we can do basic maintenance & repairs, like adjust the chain, remove a wheel or spark plug, etc.
When touring we carry a spare clutch & brake lever, clutch and throttle cable, plug/patch kit and the few additional tools to use them.  Also a small LED flashlight and a compact basic DMM.
 If a tool doesn't fit any fastener on the bike we don't carry it.
We've never needed eleven hex wrenches ;)
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 05 Aug 2018 09:00 by slmjim+Z1BEBE.
Re: my tool kit
05 Aug 2018 07:33 - 05 Aug 2018 07:35
#788227
slmjim+Z1BEBE wrote: ..........
slmjim & Z1BEBE
  True.  My bike doesn't have any fasteners that use hex (allen) wrenches.  Ed
Last edit: 05 Aug 2018 07:35 by 650ed.
  • hardrockminer
  • hardrockminer's Avatar
Re: my tool kit
05 Aug 2018 07:45
#788229
I saw one of those original plug gap gauges on ebay recently for $249 US.
I broke a throttle cable a couple of weeks ago and had the tools to change it but no spare.  It occurred to me at the time that I should check them at least at the start of the year to ensure they last an entire summer.  I used to carry tire irons and changed a couple of flats back in the day but today's tires have stiffer sidewalls (or my arms are much weaker) because all I managed to do when I tried one recently was to bend my irons.
  • slmjim+Z1BEBE
Re: my tool kit
05 Aug 2018 08:57 - 05 Aug 2018 08:57
#788230
hardrockminer wrote: I saw one of those original plug gap gauges on ebay recently for $249 US.
Hmmm... that beats the $222.00 we saw one go for a few years ago.
hardrockminer wrote:  I broke a throttle cable a couple of weeks ago and had the tools to change it but no spare.
We've heard that a closing cable can be swapped for an opener in a pinch.  No personal experience though.
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 05 Aug 2018 08:57 by slmjim+Z1BEBE.
  • hardrockminer
Re: my tool kit
05 Aug 2018 09:34
#788234
Yep, you can swap cables to limp home although I didn't think of doing that.
A couple of days ago I fired up my B4 for the first time this year.  Had to fix a carb leak and I inadvertently reversed the cables when I put the carbs back in.  Did you know the throttle works perfectly well in reverse?
Re: my tool kit
06 Aug 2018 02:35
#788308
To avoid burnt fingers, I also carry a short length of hose that fits snugly over a spark plug to grip and remove loosened hot plugs and to restart the threading of plugs back into a hot engine head.
Especially handy when performing side of the road plug readings following high speed throttle chops.
Good Fortune! :)
