I can't believe it
- menace
I can't believe it
04 Jul 2018 11:04
Im going to need help with this one boys. I just picked this baby up the body work and frame & tank are up for grabs not sure what I am asking yet for said items. I am not sure how to set the boost but I guess I will figure it out
Re: I can't believe it
04 Jul 2018 11:31
You got a tiger by the tail there bud.
Hang on tight
Hang on tight
04 Jul 2018 12:22
Moved to Bike Related ( proper category )
- zed1015
04 Jul 2018 13:36
Adjust the boost pressure via the waste gate that is attached to the exhaust just in front of the alternator..
Wind the bolt in for more boost. Wind it out for less.
- menace
04 Jul 2018 23:28
Well the plan is newer smaller inline fuel pump instead of the pop can sized one that's fried. New waist gate new boost gauge. All new hoses and plugs change the oil get a battery fix the rear brake then take it out to the strip till I burn off the shitty tire that's on it. Might have found a frame with a title. Then swap all the shit. What is the body work worth ? With the tank not included.
