Bike port
Re: Bike port
18 Mar 2025 23:24
Re: Bike port
19 Mar 2025 20:30 - 19 Mar 2025 20:31
Last edit: 19 Mar 2025 20:31 by SWest. Reason: sp
Re: Bike port
20 Mar 2025 21:42
Re: Bike port
21 Mar 2025 20:07
The following user(s) said Thank You: Rolf1976_KZ900
- Rolf1976_KZ900
Re: Bike port
22 Mar 2025 06:58
The following user(s) said Thank You: SWest, Gdizard
Re: Bike port
22 Mar 2025 08:21
Where I live is a dry climate (desert). The plywood will last a long time. I double it up for a thicker floor and for screwing the staggered pieces together. In your case I suspect the gravel is to allow someplace for the moisture to go. If that's the case I'd use copper sulfate to treat one side to stop dry rot. I had a gallon around here for fence posts but I left it on another job so I can't use it anymore. It's a good thing to have around. It is also used to keep roots from getting into drain pipes. It can be bought as a root killer for waste pipes. When I repair one I pour some in the hole then fill it with water. Once the water is gone I bury it. It's nasty stuff so don't get any on ya.
The following user(s) said Thank You: MFP-Joe, Gdizard, Rolf1976_KZ900
Re: Bike port
22 Mar 2025 21:44
Re: Bike port
23 Mar 2025 21:09
Re: Bike port
24 Mar 2025 20:47
Re: Bike port
25 Mar 2025 21:08
Re: Bike port
26 Mar 2025 21:50
Re: Bike port
27 Mar 2025 20:59 - 27 Mar 2025 21:06
Last edit: 27 Mar 2025 21:06 by SWest.
