- Thank you received: 2739
Bike port
01 Jun 2022 06:48 #867973
by SWest
Replied by SWest on topic Bike port
02 Jun 2022 11:37 #868055
by SWest
03 Jun 2022 06:27 #868116
by SWest
03 Jun 2022 12:07 #868156
by SWest
Passed the acid test.
04 Jun 2022 09:56 #868211
by SWest
- Thank you received: 1918
04 Jun 2022 11:18 - 04 Jun 2022 11:18 #868224
by Mikaw
Replied by Mikaw on topic Bike port
I’m always wanting to learn. How does drilling out the emulsion tube holes help richen the main circuit. Isn’t it restricted by the main jet no matter how large those holes are? Looking a a cutaway view of the carbs I’d guess drilling out the tube could add more air, (lean) but again that is metered buy the size of the main air jet in the carb throat.
Last edit: 04 Jun 2022 11:18 by Mikaw.
04 Jun 2022 11:45 #868226
by SWest
I opened up two of the holes Miller drilled in each to lean out the mixture. Then I added 1.2 air corrector jets that made it run too lean. If I resolder the holes closed it should be running with the stock holes and the recommended air corrector jets. That's what I meant by richening them up.
- daveo
- Thank you received: 654
05 Jun 2022 21:23 #868331
by daveo
1982 KZ1100-A2
Replied by daveo on topic Bike port
Steve, I'm running BS30/97-1.1 size Air Jets with #35 Pilot and 130 Main Jets in my 82 KZ1135 engine. The carbs are RS34's.
With BS30/97-1.2 size Air Jets, she's lean, whereas with 1.0 size she turns rich.
Those little buggers make quite a difference, but the size needs to be correct. Been through lots of trial and error, and I'm getting pretty close I think. The fuel screws are turned out 3/8 or so.
1982 KZ1100-A2
06 Jun 2022 11:36 #868363
by SWest
Getting to the little things.
06 Jun 2022 11:55 #868366
by Mikaw
Daveo. Wow. That thing must run like a scalded cat. Plugs look perfect.
- daveo
06 Jun 2022 12:47 - 06 Jun 2022 13:03 #868368
by daveo
The old three-legged neighborhood dogs keep trying, but they can't keep up with me anymore.
Gotta put credit where it's due. After Steve started talking about sticking #35 pilot jets in his carbs, I figured it was time to jump out of the 20's myself to see what could happen. Thanks again, Steve.
Been having nasty dreams of 37.5's lately, and don't quite know how to handle them.
Two things I do know, is that I have yet to reach the no return point, and these engines were built like a tank.
1982 KZ1100-A2
1982 KZ1100-A2
Last edit: 06 Jun 2022 13:03 by daveo.
06 Jun 2022 13:52 - 06 Jun 2022 13:53 #868373
by SWest
Rule of thumb, put at least 100 miles on them before making any adjustments. I'll check the plugs tonight and see what I think. The exhaust note is changing so I'll run it this way for a while.
Last edit: 06 Jun 2022 13:53 by SWest. Reason: sp
