Bike port
  • Mikaw
  • Mikaw's Avatar
Re: Bike port
26 Feb 2022 08:55
#862948
Steve, I sent you the new set not the used I just recently picked up. The used was untested so I didn’t want to skew any tests with unknown equipment. With the restrictors in you will not see full vacuum. That tool is ready to be used. When testing and adjusting the vacuum value is irrelevant. You’re looking for them to be all as equal as possible. With your number 3 carb fixed you’ll have to adjust 1,2 and 4 to match it.
www.carbtune.com/
The following user(s) said Thank You: daveo, SWest
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • daveo
  • daveo's Avatar
  • Premium Member
Re: Bike port
27 Feb 2022 06:13
#862967
Watch Steve's new VM33 Smoothbore carb sync procedural video, coming soon to a widescreen near you!
1982 KZ1100-A2
  • SWest
  • 10 22 2014
Re: Bike port
27 Feb 2022 11:55
#862976
I like these. working on the clip now. Internet is FKing up. I wonder why? NOT
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
Re: Bike port
27 Feb 2022 16:55
#862992
Hi Steve, give it a good balancing and record it while you are doing it. I'm sure people here who haven't tried it yet will appreciate a video. I used the carbtune on my KZ when I balanced mine carbs and loved it. I wish it was as easy as Z1 carbs. On he KZ you have to take off the carburetor tops to get at the individual throttle stop screws. At least on the Z1 the stops screws are out in the open. Albeit, still have to have the tank off.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • SWest
  • 10 22 2014
Re: Bike port
27 Feb 2022 17:48
#862993
Ask and ye shall receive.
The following user(s) said Thank You: KZJOE900, daveo
  • Mikaw
  • Mikaw's Avatar
Re: Bike port
27 Feb 2022 19:12
#862995
You need to adjust pilots again now.
  • daveo
  • daveo's Avatar
  • Premium Member
Re: Bike port
27 Feb 2022 19:21 - 27 Feb 2022 19:25
#862996
And after that, put new sticky grips on...cause Stevie's going to need them!
Great movie btw
1982 KZ1100-A2
Last edit: 27 Feb 2022 19:25 by daveo.
  • SWest
  • 10 22 2014
Re: Bike port
27 Feb 2022 20:16 - 27 Feb 2022 20:17
#862998
You mean 17.5's and ditch the 20's?
Last edit: 27 Feb 2022 20:17 by SWest.
  • daveo
  • daveo's Avatar
  • Premium Member
Re: Bike port
28 Feb 2022 06:23
#863003
When #'s 1, 2 & 4 slides were raised to bring #3 down, it affected the air/fuel mix in each carb. The idle-air screws may need a slight adjustment...not sure, but #3 may need the mix leaned a bit, and the others made a touch richer.
Sync check after changing a valve shim, and again after everything settles in...and whenever you feel like it.
1982 KZ1100-A2
  • SWest
  • 10 22 2014
Re: Bike port
28 Feb 2022 06:46
#863004
Tempted to put the 17.5's back in.
Heading into town today and will check the plugs this evening.
  • Mikaw
  • Mikaw's Avatar
Re: Bike port
28 Feb 2022 09:48
#863006
Yes this. Pilot screws…
