Bike port
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • SWest
  • 10 22 2014
Last edit: 19 Mar 2025 20:31 by SWest. Reason: sp
  • SWest
  • 10 22 2014
  • SWest
  • 10 22 2014
The following user(s) said Thank You: Rolf1976_KZ900
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
Re: Bike port
22 Mar 2025 06:58
#910347
You gave me an idea.I think i will try to do this in my small garage that has gravel on floor.
The following user(s) said Thank You: SWest, Gdizard
  • SWest
  • 10 22 2014
Re: Bike port
22 Mar 2025 08:21
#910353
Where I live is a dry climate (desert). The plywood will last a long time. I double it up for a thicker floor and for screwing the staggered pieces together. In your case I suspect the gravel is to allow someplace for the moisture to go. If that's the case I'd use copper sulfate to treat one side to stop dry rot. I had a gallon around here for fence posts but I left it on another job so I can't use it anymore. It's a good thing to have around. It is also used to keep roots from getting into drain pipes. It can be bought as a root killer for waste pipes. When I repair one I pour some in the hole then fill it with water. Once the water is gone I bury it. It's nasty stuff so don't get any on ya.
The following user(s) said Thank You: MFP-Joe, Gdizard, Rolf1976_KZ900
  • SWest
  • 10 22 2014
  • SWest
  • 10 22 2014
  • SWest
  • 10 22 2014
  • SWest
  • 10 22 2014
  • SWest
  • 10 22 2014
  • SWest
  • 10 22 2014
Last edit: 27 Mar 2025 21:06 by SWest.
