Bike port
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: Bike port
22 Jun 2024 11:02
#901117
Good thing I bought butt connectors just to have on hand.
rumble.com/v5335b6-wiring-the-new-rr.html
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Re: Bike port
22 Jun 2024 12:52
#901132
Best to stagger your splices if poss, otherwise you will have a loom that looks like a snake that swallowed a goat (big bulge)
  • SWest
  • 10 22 2014
  • SWest
  • 10 22 2014
  • SWest
  • 10 22 2014
  • asphalt900
  • asphalt900's Avatar
Re: Bike port
23 Jun 2024 07:03
#901176
Boobie/knocker jealousy and reality in just two snaps, Love it!! Keep them coming!!
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
Re: Bike port
23 Jun 2024 12:08
#901187
Have not watched all videos but if the problem is that the plugs dont spark it can be a fault with the sidestand switch or the fuse for signals is blown.
That is a safety thing i think .Once my fj1200 cranked but no spark then it was a fault in the sidestand switch.Another time it canked with no spark it was a short in the rear brake light wiring shorting to frame so the signal fuse was blown.
  • SWest
  • 10 22 2014
Re: Bike port
23 Jun 2024 13:42
#901194
You may have just touched on it. If the sidestand is down it won't fire?
  • Rolf1976_KZ900
Re: Bike port
23 Jun 2024 13:49
#901195
Not exactly because if sidestand down the starter does not operate .But if sidestand switch is bad i can crank with no spark for some reason. and if a blown fuse to the signals on the fj it cranks but does not spark.
It may also be if your bike has a clutch switch that is bad it cranks with no spark.many strange safety things !
maybe try to jumwire the switches just disconnect one by one and put a little piece of wire in the connector
Wookie should maybe have better advice =)
  • SWest
  • 10 22 2014
The following user(s) said Thank You: Rolf1976_KZ900
  • SWest
  • 10 22 2014
  • SWest
  • 10 22 2014
