Owners Manual 1978 Kawasaki 1000 LTD
- perrykz1000
- Have a safe day !!
24 Mar 2018 09:44
Looking for a owners manual PDF or orginal. Appreciate any help or information. Also would like to know whay you all think approximate value is of this bike wit 23,000 miles and above average condition. Thanks.
- ajsfirehawk
Re: Owners Manual 1978 Kawasaki 1000 LTD
24 Mar 2018 12:56 - 24 Mar 2018 12:59
Cool bike. If your question is for insurance purposes I'd insure it for $3,500 to $4000. Value is a strange creature. Time of year, regional differences all make a big difference. A clean bike in Spring is going to bring a lot more than it is in Nebraska in Oct. A lot. You have a nice bike but if an appraiser evaluates it they are going to take off for non-stock items. No airbox, doesn't have the stock pipes/mufflers, and I don't believe that is a stock color for an LTD. I think you have a standard with an LTD seat. The backs of the gauges are black not chrome. Not in the US anyway. As always "Beauty is in the eye of the beer holder." You may come across a dude that loves the pods and the 4 into 1 because they were going to do that anyway. Thanks for the pics. The color might well be correct for the standard model. I''m not as well versus in those models.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
Last edit: 24 Mar 2018 12:59 by ajsfirehawk.
The following user(s) said Thank You: perrykz1000
- ajsfirehawk
24 Mar 2018 13:01 - 24 Mar 2018 13:13
PS - I would NOT ride more than around the block on those tires. I don't even know who was president the last time they made raised white letter tires. Laying in a hospital versus $400 for tires is a no contest decision. Apologies if you already knew this but not worth the chance.
I just looked it up. It appears to be a stock paint scheme (A very good thing IMO) for a 1978 A2
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
Last edit: 24 Mar 2018 13:13 by ajsfirehawk.
- perrykz1000
24 Mar 2018 16:25 - 24 Mar 2018 16:27
Suppose to be new tires what I was told. I have not recieved the bike yes but, will soon. For sure I will be checking into the tires for sure. (replacing)
Thanks ,Perry
Thanks ,Perry
Last edit: 24 Mar 2018 16:27 by perrykz1000.
- mopguy
24 Mar 2018 18:20 - 24 Mar 2018 18:27
1978 kz1000 ltd's came in two colors black and cardinal red and pinstriping is silver and red
www.robswheels.com/robswheels/my_bikes/k...1000_ltd_78_002.html
www.2040-motos.com/Kawasaki/Other/1978-k...z1000/78KZ1000_1.htm
yours is
www.artedelstein.com/oldbikes/78kz1000/78KZ1000_1.htm
As far as manual goes, any 1977/78 KZ1000 Kawasaki Motorcycle Service Manual will do.
yours is
Last edit: 24 Mar 2018 18:27 by mopguy.
25 Mar 2018 05:15 - 25 Mar 2018 05:19
Bike is a LTD based on everything except tank and paint .
Look at the frame. Specifically the tubing which forms the rear foot peg mounts .
Then look at the 78 KZ 1000 attachment . The rear peg area is done in KZ style with the dropped hanger style mount .
I have the factory manual supplement which does deal with the few mechanical differences from a stock style KZ.
LTDs also had a different owners manual which contained proper service procedures and fit in the rear tail piece tray
Brake rotors are wrong for a 78 LTD ( Should not be drilled ) and gauges should be chrome on bottom half and top half black
Cant see some other details to go further
Nice Bike though.
Nice Bike though.
Last edit: 25 Mar 2018 05:19 by Street Fighter LTD.
- ajsfirehawk
25 Mar 2018 10:22Street Fighter LTD wrote: Bike is a LTD based on everything except tank and paint .
Nice Bike though.
Nice recognition tip on the frame for the rear foot pegs. An obvious and easy way to pick off the model for something not easily changed. (like gauge covers) I also noticed it had the chrome chain guard instead of the crappy plastic one. The back of the headlight is chrome (an LTD thing) whereas a model A/A2 would have a black rear cover.
Perry; when do you get your new girlfriend? Is she running? Inquiring minds want to know.
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
- perrykz1000
25 Mar 2018 11:50 - 25 Mar 2018 13:52
Be here in 20 minutes came from texas. more to come shortly Perry
Runs good far as I can tell (little cold outside) Rode about 2 miles . Carbs are leaking looks like from float bowl area left side. I MIGHT try to replace all the float bowl gaskets and replace screws with allan head ones. Can this be done with carbs on bike?? Thanks for all the replies.. Perry
Last edit: 25 Mar 2018 13:52 by perrykz1000.
- ajsfirehawk
25 Mar 2018 20:18
I wouldn't. You might want to get a shorty philips head screwdriver and verify they are tight before pulling them. Don't go full moose and crank the dickens out of those screws. You could pull threads, crack a bowl. Firm but not cranked. With pods on the bike the carbs come off quite easily. Once removed I would do the clear tube test to verify the float height. Quite simple, peek at your service manual or I'm certain there are several threads you can search here to get a step through of the process.
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
- perrykz1000
21 Aug 2018 16:14
ajsfirehawk ---- I went with the Dunlop Elite 4 tires.... These white letter tires were new (New Old Stock) date code on front was 2000 , rear tire was 2004. Thanks for the heads up. Take Care....
21 Aug 2018 16:24
It's easy to tell if it's an LTD or some other model. Just look at the S/N on the frame. If it's KZTOOA then it's a standard model. If it's KZTOOB then it's an LTD. Also called a B2.
- perrykz1000
