Combine 2 Models
  • Oldschoolkz1000
  • Oldschoolkz1000's Avatar Topic Author
Re: Combine 2 Models
05 Oct 2017 16:01
#772396
I sold the 1982 KZ1000, I want to run the 1980 model, I have located a 1977 KZ1000, just double checking. Does the parts from the 1977 mount the same to the 1980. I need engine and all the wire harnesses from the 1977 to mount onto the 1980 frame. Thanks for all the help
  • KZ Rat
  • KZ Rat's Avatar
05 Oct 2017 16:59
#772398
Should be vey close if not the same, The 77 would have come with points-the 80 would have been electronic ignition but physically everything else should be the same. As long as you're swapping the whole motor-if you try to do the cylinders onto the existing bottom end I suspect you are going to find your upper case half has been machined to accept the oversize liners for the big bore kit.
1979 ltd 1260 1980 ltd 1075 2005 450x for the desert
  • Oldschoolkz1000
05 Oct 2017 17:27
#772403
I am planning to use the whole motor. If it still has points I can get electronic ignition parts for it. Just want to make sure the motor mounts are the same.
  • Oldschoolkz1000
05 Oct 2017 17:54
#772404
As you can see, the bike I'm trying to get back on the road has been sitting a while. I just want to ride it for now.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
05 Oct 2017 21:19
#772413
Oldschoolkz1000 wrote: I have located a 1977 KZ1000, just double checking. Does the parts from the 1977 mount the same to the 1980. I need engine and all the wire harnesses from the 1977 to mount onto the 1980 frame. Thanks for all the help
Yes, the 1977 and 1980 KZ1000 engines should have the same mounts. It should go right in. It's interesting that your engine serial number says it's an 80, but looking at the pictures, all of the covers are from a 77/78.
The wiring harness might be harder to adapt. I don't know how much changed between 77 and 80, but I'm certain there were changes (regulator/rectifier, electronic ignition, etc). I think they also removed the central harness connector block. But the frames were basically unchanged from 77 to 80, so if you really just take the whole thing, along with the brackets and stuff, and move it from one bike to the other, it's likely to just work.
What does the harness on the '80 look like? Is it all hacked up?
What kind of ignition is on the '80 now?
If you swap the entire '77 harness, you might want to replace the points with a Dyna S ignition. They are easy to install and work well.
www.z1enterprises.com/dyna-s-ignition-ds2-1-z1-kz900-1000.html
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: Oldschoolkz1000
  • Oldschoolkz1000
15 Oct 2017 20:30
#773030
Thanks for all the help, The wire harness is all hacked up. I have decided to use the bike I have. I am going to start a new thread and name it Tribute Bike.
