Helmet lock
- Epicface803
Helmet lock
12 Dec 2016 09:25
Just out of curiosity does anyone know how to properly use the original helmet lock on the 82 kz1000
- stokes
Re: Helmet lock
12 Dec 2016 10:38
I have a 1980 KZ1000,I would think it would be the same.Just lift the seat,hang the helmet on the hook and close/lock the seat.
1980 KZ1000B Ltd
- BOOM_FIST
Re: Helmet lock
12 Dec 2016 14:18stokes wrote: I have a 1980 KZ1000,I would think it would be the same.Just lift the seat,hang the helmet on the hook and close/lock the seat.
^^^This^^^ - I think a lot of bikes are set up this way.
1977 KZ900A5
Re: Helmet lock
12 Dec 2016 14:39
Assuming it's a 1000-K Ltd, the helmet locks appear to be the same as my 81 650-CSR.
The helmet hook at the seat has a push-button that's spring loaded. push the red button to open. push the pin to close.
The rear helmet lock is on the right side of the bike & is operated by a key.
- Epicface803
Re: Helmet lock
13 Dec 2016 14:34
Yeah the lock is the same on my 82 csr I was just wondering the correct way to hang the helmet I've never used a helmet lock at all I was wondering if there was a correct way to hang the helmet do you use the strap? And is it safe to ride with the helmet on the lock I got the basic operation just wondering if there is a correct and/or incorrect way to hang the helmet on this lock specifically
- rstnick
Re: Helmet lock
13 Dec 2016 15:16
Usually you can hook the helmet by the metal D loops.
Make sure the helmet or any loose strap (tie it up!) cannot get caught in the rear wheel, chain, shock etc.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- SmokyOwl
Re: Helmet lock
13 Dec 2016 17:21
Yeah that lock is really awkward to use. The cushion squishes my D rings and it's really tight, wish the opening was a little bigger. Luckily I have a 2nd lock on the other side, it's easier to use.
1982 Kawasaki KZ1100 A2, Shaft
Never trade the thrill of living for the safety of existance.
