ATP turbo air cleaner options
- GregZ
20 Aug 2016 13:14
Hey guys
Anyone know if there is an alternative air cleaner option for Zenith/bendex carburetor. I'm not too thrilled with the cheapo chrome assembly.
cheers
cheers
- rstnick
Re: ATP turbo air cleaner options
20 Aug 2016 14:34 - 20 Aug 2016 14:39
John Sly/stone fruit (not sure if he's a member here) is putting an ATP on his kz650.
Here's his carb and filter, not sure if it's the same as yours.
Looks a bit thicker.
I'll ask him if he knows of options.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
Last edit: 20 Aug 2016 14:39 by rstnick.
- stone fruit
20 Aug 2016 15:30
Hi Greg,
If you plan on using the Zenith 13792 carb there are a number of filter housings out there. Just search under Harley Bendix/Zenith air filter. Another option is a velocity stack. I'm thinking I might make an outer cover from 3mm aluminium. I have the same filter as you.
- GregZ
20 Aug 2016 17:39
Ok I'll check out ebay for air cleaners
One more question where can I source intake manifold and all the exhaust pipe gaskets
- stone fruit
20 Aug 2016 20:21
Mr Turbo will have the gaskets if it's a 900/1000 engine. Flange gaskets can be found at auto parts stores. Mr Turbo has old style wastegate gaskets but they didn't fit my wastegate. I bought a sheet of exhaust gasket from an auto parts shop and made my own. If you do this make a few spares as I have. It'll save time later on.
- GregZ
24 Aug 2016 05:16
Well I thought i was pretty good at finding anything on the internet, however I cannot find anything related to ATP turbo mr turbo, nothing
How about a part number or link for repalcement air filter, 5 1/4" OD x 2"
24 Aug 2016 05:38
24 Aug 2016 07:18
Greg
While looking at the Mr Turbo site you could look at the Mikuni carb set up now running on a system like yours.
Most KZ turbo guys made the upgrade years ago. Some because of lack of replacement parts for the old carbs , Some because it was such a better carb to run and tune.
Just a thought
Just a thought
- stone fruit
27 Aug 2016 14:31Go to K&N website & cross match the filters dimensions. I believe the ATP filter is discontinued but there is one which is close enough.GregZ wrote: Well I thought i was pretty good at finding anything on the internet, however I cannot find anything related to ATP turbo mr turbo, nothing
- GregZ
27 Aug 2016 15:04 - 27 Aug 2016 15:05
No eBay APP ID and/or Cert ID defined in Kunena configurationThis is about as close as I can find. I'll have poke a couple holes in it for the cover.
For now I just want to make it runner and possibly get the Mikuni carb set up later
Last edit: 27 Aug 2016 15:05 by GregZ.
