Will an air box from a gpz1100 fit a 1984 gpz900?
- DenimDean
11 Jun 2016 11:08
No eBay APP ID and/or Cert ID defined in Kunena configurationI've been searching for awhile and can't find the answer. I have a 1984 gpz900 and can find a factory air box for it and don't want to go through the hassle of trying to get it running right with pod filters. Thanks!
Here's the air box for the gpz1100 I found
- StreetfighterKz
Re: Will an air box from a gpz1100 fit a 1984 gpz900?
11 Jun 2016 11:39 - 11 Jun 2016 11:41
I doubt they'll swap. If I remember correctly the Gpz900 has a cam chain on the outside while the Gpz1100 has a center drive chain. This means the carbs on the 900 are spaced closer together, especially the middle two carbs compared to the 1100. Also the 1100 were fuel injected and the OD of the throttle bodies will most likely be smaller than the 900's CV carbs inlet OD.
Not saying you can't make it work, but I don't think it'll be worth the hassle.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 11 Jun 2016 11:41 by StreetfighterKz.
- DenimDean
11 Jun 2016 11:58StreetfighterKz wrote: I doubt they'll swap. If I remember correctly the Gpz900 has a cam chain on the outside while the Gpz1100 has a center drive chain. This means the carbs on the 900 are spaced closer together, especially the middle two carbs compared to the 1100. Also the 1100 were fuel injected and the OD of the throttle bodies will most likely be smaller than the 900's CV carbs inlet OD.
Later, Doug
I was worried about that. Looks like I'm gonna be living on ebay until one pops up. Thanks.
- Mcdroid
- Gone Kwackers
11 Jun 2016 12:28DenimDean wrote:StreetfighterKz wrote: I doubt they'll swap. If I remember correctly the Gpz900 has a cam chain on the outside while the Gpz1100 has a center drive chain. This means the carbs on the 900 are spaced closer together, especially the middle two carbs compared to the 1100. Also the 1100 were fuel injected and the OD of the throttle bodies will most likely be smaller than the 900's CV carbs inlet OD.
Later, Doug
I have grown to love eBay...much to my wife's dismay...
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- DenimDean
11 Jun 2016 12:51
[/quote]
I have grown to love eBay...much to my wife's dismay...[/quote]
Haha same here. I've spent a lot of time and money on there the last couple of weeks.
11 Jun 2016 15:47 - 11 Jun 2016 15:49
From a quick visual comparison at Partzilla the 84 ZX900 GPz airbox looks the same as the ZG1000 Concours. I have no idea if there are significant differences, such as the duct hole ID or spacing. they do share some parts, but I didn't compare everything.
Last edit: 11 Jun 2016 15:49 by martin_csr.
- DenimDean
19 Jun 2016 07:57
An air box from an 86 gpz 900 will fit my 84 right? I found a guy locally who has one.
