1983 KZ1100 LTD front fork diameter?
  • kz_fl
  • kz_fl's Avatar Topic Author
21 Oct 2015 15:19
#695374
Hey guys. I'm stumped. I'm looking all over, but can't seem to find this information. I have a 1983 KZ 1100 LTD model. I want to replace the stock boots on my front forks with the lower profile dust seals that come on the A, B and D models. However, I can't find ANYWHERE if the forks are the same size on the different models. Does anyone know specifics on this? Please help. Thank you!
1980 kz650
1983 kz1100 LTD
  • martin_csr
  • martin_csr's Avatar
Re: 1983 KZ1100 LTD front fork diameter?
22 Oct 2015 02:58 - 22 Oct 2015 03:40
#695436
Z1Enterprises.com lists the fork seals for the KZ1100-L1 as 38 mm. From the diagrams at Partzilla the L1 has the same fork tube lowers & fork seals as the 1100-A3, so the A3 dust boots should fit --- Z1Ent has them. Although I did not see your model listed, the OhioCafeRacers site has a fork tube conversion pdf that comes in handy from time to time.
Last edit: 22 Oct 2015 03:40 by martin_csr.
