strange behavior
  • 82 kz250l
  • 82 kz250l's Avatar
Re: strange behavior
10 Sep 2015 13:48
#689517
kayodash wrote: If it were an ignition problem why would it arise after the bikes been rode for a while?
Most of the time when a coil is going bad. the engine will do what your describing. when it's operated for 30 min or more. It won't do it all the time untill it goes completely bad
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 Sep 2015 13:49
#689518
I gave my bike a bath before I rode to my daughter's place. About 50 miles, it started cutting out on one cylinder, then two. I limped up there, took off the tank and switched out the coils. Fired right up. The next morning I was looking at the coils I'd pulled out. Water had gotten into one of the connectors for the #3 H/T lead. Green SHT. That's all it was. Next time I take the tank off, I'll put back my 4 OHM coils. I carry spares or I would have found it sooner. Something stupid again. :S
  • kayodash
  • kayodash's Avatar Topic Author
10 Sep 2015 14:17
#689526
Yeah I guess I'll pull the tank and check them out. You guys are right, I think I'm not wanting that being a possibility from thinking it was the problem on my van, pretty much similar symptoms between the two, ended up being the fuel pump, off topic.
1984 Kawasaki KZ550 LTD F2
1981 Kawasaki KZ750 LTD
  • jackleberry
  • jackleberry's Avatar
10 Sep 2015 14:54
#689532
Water on the spark plug wires/coils usually clears up after the bike warms and the water evaporates though...
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 Sep 2015 15:32
#689533
Think about all the stuff that collects on battery terminals. When it gets bad enough, it will stop high Amps from flowing. Coils have next to no Amps so just a little sulfation or tarnish will keep them from working.
  • kayodash
12 Sep 2015 16:57
#689801
Went and tested the ignition coils, set the ohmeter to 200, leads on where the wires hook to it, got 2.7-2.8 resistance on each side. Checked manual says resistance of 4 ohms. Can anyone confirm?
  • kayodash
12 Sep 2015 18:42
#689815
I'm getting no change, probing any contact on the coil and plug wire in any combination on either side..
  • jackleberry
12 Sep 2015 22:55
#689826
kayodash wrote: I'm getting no change, probing any contact on the coil and plug wire in any combination on either side..
No change of what?
They could be 3ohm coils, I'm not sure with that model, but the fact is that if you pull the plug and look at the spark (or use a spark tester or colortune or whatever) and see a decent spark, then the coils, wires, and plugs are fine. A big enough ignition problem to cause poor running will always be visible as a missing/weak spark.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • kayodash
13 Sep 2015 03:57
#689832
No change in resistance
  • LineArtist
  • LineArtist's Avatar
13 Sep 2015 09:04
#689865
Cant' really answer your questions without knowing the FSM spec on coil range. Are the coils cracked or damaged visually (look underneath)?
Pictures?
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
