- Thank you received: 1918
1975 KZ900? new to me
Patton wrote:
Mikaw wrote:
Kidkawie wrote: Those 900's are pretty rare. If the engine and frame numbers are around 200 or so off, it's considered matching numbers. Great candidate for restoration.
Don't want to hijack this thread so if I'm in the wrong, sorry. My question might help us understand the "numbers matching". I have a 76 KZ900 A4. From what I can decipher from the vin is its a US made bike VIn is Z1F 5027XX. My real question is with a motor vin of Z1E 0941XX
Zedder shows the range of vins and engine numbers for many motorcycle models.
These steps will produce the link shown below.
Go to www.zedder.com
> Bike Info
>Kwasaki Model Information
>900 cc arranged by year
>1976 KZ900-A4
The above steps should produce this link:
www.zedder.com/Info/76%20KZ900-A4.htm
The information shown in the link includes the following:
Year & Model '76 KZ900-A4
Color(s) (1) Dia Dark Green
(2) Dia Brown
Frame No. Range Japan MFR Z1F-085701 - 117060
USA MFR Z1F-500001 - 510340
Engine No. Range Z1E086001 - 138846
Patton, I actually learned about Zedder from you in a different post and that's how i decoded the 900 A4 I own. Look at the last two lines in your quote. Those numbers represent my situation, A US frame and in the 500K to 510K range and a motor in the 86K to 138K there is no way my bike can have a frame and motor number within a couple hundred.
- Kidkawie
- I bleed premix
- Thank you received: 245
Mikaw wrote: there is no way my bike can have a frame and motor number within a couple hundred.
That only applies to JAPAN bikes, not USA.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- MDZ1rider
- Thank you received: 118
If this holds true for the US 900's, your frame was the 27xx produced. The engines started with 086001, so the engine S/N should be +27xx, or 0887xx. Adding the 200+/- would give an expected engine S/N of 0885xx to 0889xx.
Having said that, none of the above may apply to the US models. Kawasaki could have had 10,000 engines sitting in a warehouse waiting for frames When the production started, they used whatever engine was closest to the front of the warehouse. Any records where lost long ago.
The bottom line is no one can prove or disprove your bike has the original engine... but who cares? Numbers only becomes a factor in 100% original collector bike pricing. Matching numbers go far beyond just the frame/engine in that market. Unfortunately collectors aren't getting in bidding wars (yet) for original KZ900's anyway. Enjoy your bike for what it is. You've got a nice KZ900. Ride when ever you can with a grin from ear to ear. That's the real value of any bike IMO.
- KZ802
- Thank you received: 13
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
MDZ1rider wrote: There's several user data bases for the Japanese 900's to create a "rule of thumb" for matching engines. Basically an Engine S/N 200+/- from the frame VIN is accepted as matching. There are proven exceptions to every rule.
Thank you, I wasn't trying to prove or disprove originality of my bike. I was trying to understand the correlation between the significantly larger frame numbers on a US bike verses the Japanese frame numbers and their relation to engine numbers. I thought I may have been missing something. I will take enjoyment in riding my bike knowing that it was the origin of today's super bikes. Every time i start it the sound takes me back to high school and cruising on Friday nights looking for a hot-rod to put in their place!!!
