zr550 top speed
  • Zaddict
  • Zaddict's Avatar Topic Author
  • Enjoying my Zaddiction!
zr550 top speed
16 May 2015 23:08 - 17 May 2015 10:04
#672450
I hit 110 mph on my Zephyr 550 the other day and still had a 1000 rpm to go till the 10000rpm redline. I haven't found any good top speed stats online, but I'm guessing it's 119mph like the GPZ550. I was kind of (pleasantly) surprised how well she kept pulling.
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
Last edit: 17 May 2015 10:04 by Zaddict.
  • JR
  • JR's Avatar
Re: zr550 top speed
17 May 2015 05:32
#672458
These bikes might be termed "small fours" but they are definitely not "slow fours" :)
ride safe
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
Re: zr550 top speed
17 May 2015 07:24
#672475
For theory, play with this:
www.gearingcommander.com/
My GPz can regularly hit 120 mph with no problem, but actual results may vary.
'85 GPz550(ZX550-A2)
  • TexasKZ
  • TexasKZ's Avatar
Re: zr550 top speed
17 May 2015 11:58
#672499
Also keep in mind that Kawasaki speedometers are notoriously optimistic, often 8-10%.
  • loudhvx
  • loudhvx's Avatar
Re: zr550 top speed
17 May 2015 13:32
#672513
I had mine near 120 many times. I don't use a speedometer. I use an electronic tach that I calibrate on a scope, then convert that mph. All of the chain-drive KZ bottom ends used the same gearing. I'm not sure if the ZR did as well, or not.
  • CoreyClough
  • GPz550 Addiction
Re: zr550 top speed
18 May 2015 05:04
#672588
loudhvx wrote: I had mine near 120 many times. I don't use a speedometer. I use an electronic tach that I calibrate on a scope, then convert that mph. All of the chain-drive KZ bottom ends used the same gearing. I'm not sure if the ZR did as well, or not.
The ZR550 and GPz550 use the same 6 speed gearing.
