85 kawa zn700 ltd, trans?
- bb41077
28 Apr 2015 20:07 #669926
by bb41077
Bruce Bakken
85 kawa zn700 ltd, trans? was created by bb41077
So I can't seem to Get this bike to go into total release when I pull the clutch in. So when I shift it stalls out as soon as it thuncks into gear.I just got the bike and it didn't start so I didn't check much out, well ui put in the starter clutch in and got it to start. But the clutch thing I'm not understanding why it disengage all the way. Or is it not suppose to? I have it torn back apart some so I can check things I did. But I did find 2 gouges on the push rod, I think its called, how f'ed up am I here
Bruce Bakken
- Thank you received: 1656
29 Apr 2015 06:15 - 29 Apr 2015 06:26 #669951
by martin_csr
Replied by martin_csr on topic 85 kawa zn700 ltd, trans?
I would do a basic clutch/cable adjustment. If you need a manual, search eebbaayy for KZ750 shaft manual & get one that covers at least 1985. If you find a really cheap 84 manual, it might be sufficient as it covers the ZN700-A1 which is probably very similar to yours (if not virtually identical).
I'm not familiar with the shaft drive models, but the clutch release mechanism is different from most KZs. On your type of clutch, if cable adjustments cannot be done, I think the manual will say to replace the cable.
From the diagrams at Partzilla there is an inner & outer clutch push rod. I would replace the damaged part or parts, install a new cable, then do the adjustment. The push rod might be available at the dealer as it was used on the Vulcan 750.
Last edit: 29 Apr 2015 06:26 by martin_csr.
- bb41077
29 Apr 2015 11:55 #669981
by bb41077
Bruce Bakken
Replied by bb41077 on topic 85 kawa zn700 ltd, trans?
But it is suppose to go into a free spin when I pull the clutch in right.cuz it don't seem to
Bruce Bakken
29 Apr 2015 12:52 #669986
by martin_csr
On my 81 650 chain drive the rear wheel can be spinned by hand only in neutral.
In gear I can pull in the clutch lever & roll the bike around, but the rear wheel does not spin freely by hand on the center stand in gear w/ the clutch disengaged (lever pulled in).
- bb41077
29 Apr 2015 14:56 #670010
by bb41077
Bruce Bakken
I had it running on the center stand and I put it into gear and the tire will spin, I can pull the clutch in and the tire still spins it never seems to be in the full neutral area. Or isnt it suppose to???????. Thanks
Bruce Bakken
- Thank you received: 2829
29 Apr 2015 15:01 #670013
by 650ed
Replied by 650ed on topic 85 kawa zn700 ltd, trans?
That's not a problem unless there is real force spinning that wheel with the clutch pulled in. Can you stop it from spinning with your hand or foot with the clutch pulled in? If so, don't worry about it because it is simply the friction of the oil between the clutch plates that keeps the wheel moving. Ed
The following user(s) said Thank You: bb41077
- bb41077
- bb41077
29 Apr 2015 19:27 #670050
by bb41077
Bruce Bakken
Ya but actually It has force. I click it into 1st and I can pull the clutch in and it still has power to it.
Bruce Bakken
- bb41077
03 May 2015 08:36 #670492
by bb41077
Bruce Bakken
Everything seems to work good now. Except I think it needs ignition coils cuz only 2 outta 4 fire
Bruce Bakken
03 May 2015 20:18 #670580
by martin_csr
As already suggested, try doing the basic clutch adjustment as per the factory service manual.
Many a rider has solved a problem by the basic procedure.
03 May 2015 20:35 #670582
by 650ed
Sounds like your coils might be hooked up to the wrong plugs. One coil fires cylinders 1 & 4; the other fires 2 & 3. Do you know which cylinders are firing and which are not? Ed
bb41077 wrote: Everything seems to work good now. Except I think it needs ignition coils cuz only 2 outta 4 fire
