- Thank you received: 8
KZ650 Fuel Petcock fails on the way to work...
- Spencer440
1980 KZ440-B
1979 Kawasaki KZ650-C3
- Thank you received: 2829
What are you calling "the bleed off channel"? Ed
- Spencer440
1980 KZ440-B
If so, take a look at the link below for details on how to rebuild. Ed
www.xs650.com/forum/showthread.php?t=20662
- Spencer440
1980 KZ440-B
- RonKZ650
- Thank you received: 241
- Thank you received: 1645
Edit: I forgot to add that you may have to remove the vac line & cap the ports, because if the diaphragm is torn, it'll act as a vacuum leak, so the bike may run poorly. I happen to keep spare vac caps in the tool tray, along w a few zip ties & cotter pins.
- Spencer440
Yeah, when I switch it to prime, it gives it gas, but still leaks some around the petcock....martin_csr wrote: If the diaphragm fails, I think you should be able to switch it to PRI so that you can get home. I actually rode my bike a couple of weeks like that, with the vacuum line removed & the ports capped. ON-RES functioned as off & PRI as ON. confusing, ain't it.
1980 KZ440-B
- Spencer440
1980 KZ440-B
- RonKZ650
