Z2 750 crank (Bossie the Kaw)
Re: Z2 750 crank (Bossie the Kaw)
01 Aug 2020 15:33
They seem to work.
01 Aug 2020 15:38
You can get the length of any bolt from the Partzilla parts diagrams. The long ones are Part # 112G06125. The last 5 numbers indicate that it's a M6 bolt, 125 mm long.
01 Aug 2020 19:20
SWest. Glad to see so far they are working out. If the bolt is bottoming out, could you just cut 1/4” of thread off?
01 Aug 2020 20:52
That's what they say you might have to do.
02 Aug 2020 06:54
Now to RIDE. :woohoo:
04 Aug 2020 18:45
They were glazed.
04 Aug 2020 21:13
I should have cleaned all the plates.
- Greybeard
05 Aug 2020 06:29
Are those springs still in spec?
1982 KZ1100 D-1
05 Aug 2020 06:45
Well over spec. It must have been the pre mix I'd been using to flush out the engine.
The following user(s) said Thank You: Greybeard
06 Aug 2020 15:17
Should have done this the first time.
06 Aug 2020 19:44
Looks like it will work.
11 Aug 2020 07:44
More to do but at least I can ride.
