Z2 750 crank (Bossie the Kaw)
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: Z2 750 crank (Bossie the Kaw)
26 Dec 2018 18:38 - 26 Dec 2018 21:53
#795734
Doing maintenance after the trip.
Last edit: 26 Dec 2018 21:53 by SWest. Reason: Edit video
  • missionkz
  • missionkz's Avatar
27 Dec 2018 13:09
#795780
I would be quite worrisome if I was using a quart of oil in under 300 miles.
After about 5000 miles on my 1075cc top end rebuild, ... sleeve bore and hone, pistons, rings, pins, head rebuild with new valve guide seals... etc... I'm still only using about 2-4 ounces every 2000-2200 miles, which is where I have always stopped and changed the oil and filter since the first year I owned the bike in 1977.
What do you suppose is the cause of this oil consumption, Steve?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • 10 22 2014
27 Dec 2018 14:52
#795786
Used rings/ valve guide seals.
  • missionkz
27 Dec 2018 20:13
#795811
With spark plugs out, are you seeing oil on the back side of the intake valves? A new set of +2mm rings is like over $100.00 plus the cost of a new base gasket and head gasket. A bummer and PIA in the winter... actually any time.
Bruce
1977 KZ1000A1
  • SWest
  • 10 22 2014
27 Dec 2018 20:49 - 27 Dec 2018 20:51
#795812
I have one set of rings, I need three more and renew the head. With my new heated shop I can do it anytime.
Last edit: 27 Dec 2018 20:51 by SWest.
  • SWest
  • 10 22 2014
29 Dec 2018 18:33
#795897
Much more to do. :unsure:
  • SWest
  • 10 22 2014
30 Dec 2018 07:21
#795915
Daily rider since 13 so there are always something to fix. The harsh desert elements take their toll. At least I can still ride most of the year. B)
HAPPY NEW YEAR :woohoo:
  • SWest
  • 10 22 2014
31 Dec 2018 07:43
#795965
Got them back on but still need minor adjustments. The boxes need paint so I'll do it then.
  • SWest
  • 10 22 2014
01 Jan 2019 07:35
#796005
Too cold and windy to ride so I adjusted the box. Fork seals are next.
  • SWest
  • 10 22 2014
01 Jan 2019 19:45
#796035
Too cold and windy to ride again so I started on the fork seals.
  • SWest
  • 10 22 2014
02 Jan 2019 08:25
#796061
It took all day.
  • SWest
  • 10 22 2014
02 Jan 2019 11:44
#796071
And after dark.
