Z2 750 crank (Bossie the Kaw)
Re: Z2 750 crank (Bossie the Kaw)
27 Feb 2018 19:46
Clutch better now.
01 Mar 2018 15:07
I think I'll just move the left box over 1/2".
03 Mar 2018 17:41
Had to send them back.
04 Mar 2018 16:11
It was a nasty noise. Sounded like the bottom end was about to grenade at low idle. Got lucky,,,,,,,this time.
06 Mar 2018 21:03 - 06 Mar 2018 21:04
100 miles of hard riding and it's still quiet.
Last edit: 06 Mar 2018 21:04 by SWest. Reason: sp
11 Mar 2018 20:09
Not too bad.
18 Mar 2018 21:48
Got my driving lights again. I hope these last this time.
20 Mar 2018 21:23
The squeak was driving me nuts. :pinch:
- missionkz
21 Mar 2018 15:27
Steve,
I'm curious if you've replaced the front wheel bearings in a while and is the pseudo axle shaft you are using for this jig, the exact same diameter as a real axle shaft?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
21 Mar 2018 15:56
Bearings are recent. The shaft isn't the same size as the axle. The bearings spin freely.
- missionkz
21 Mar 2018 19:39
Ok. I would think that if the shaft is a bit too much smaller, the geometry would be that the mass would be slightly below the center of rotation and make it a bit harder to balance using gravity.
Bruce
1977 KZ1000A1
1977 KZ1000A1
22 Mar 2018 07:18
As long as the bearing spins freely I doubt that would be an issue. When I change the tire I'll try it with the axle first to check my work. So far no hop.
