Z2 750 crank (Bossie the Kaw)
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: Z2 750 crank (Bossie the Kaw)
14 Dec 2017 11:25
#776034
Yeah, you guys are right. I should have known that. I'm too young for a senior moment. :unsure: That's a crutch I don't care to rely on.
  • SWest
  • 10 22 2014
17 Dec 2017 15:00
#776222
Got the rotor on. It was pulsing but after some hard braking, it seems to be going away.
  • SWest
  • 10 22 2014
17 Dec 2017 21:54
#776277
One thing fixed, another one appears. :dry:
  • missionkz
  • missionkz's Avatar
19 Dec 2017 11:38
#776346
Using my old early 70's Snap-0n light gun, mine does the jiggle a lot more then when I use my other much newer strobe, the Craftsman light. No idea why.
However, I've noticed that I can jiggle the weights a little now where the springs don't seem to hold them as steady any more.
Could be the weights are moving around the pins or the springs are loose... ??
Only about 42,000-45,000 miles on my advance mechanism but I bet I'll be doing the same thing this spring.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • SWest
  • 10 22 2014
19 Dec 2017 13:45
#776352
The spring ends get loose. Made a big difference and the knock has all but gone away. It was making the engine stumble at idle. Also the bolt was slightly bent. Going to try and time it again.
  • missionkz
19 Dec 2017 15:51
#776362
Bent bolt.
I noticed that in your previous video but I thought it was an illusion from just the cam lobe itself oscillating.
Bruce
1977 KZ1000A1
  • SWest
  • 10 22 2014
19 Dec 2017 16:43
#776367
It's the second rotor. Should have replaced it long ago. :whistle:
  • SWest
  • 10 22 2014
19 Dec 2017 19:31
#776382
I changed to title to move on. This will be where I post maintenance and engine upgrades.
  • SWest
  • 10 22 2014
20 Dec 2017 16:28
#776433
Each time a little better.;)
  • SWest
  • 10 22 2014
20 Dec 2017 18:50
#776440
Slowed the leak down some.
  • SWest
  • 10 22 2014
20 Dec 2017 21:53
#776445
Not done yet. :dry:
  • SWest
  • 10 22 2014
21 Dec 2017 21:14
#776478
Getting some things done.
