Z2 750 crank (Bossie the Kaw)
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: Z2 750 crank (Bossie the Kaw)
17 Mar 2017 19:16 - 17 Mar 2017 19:17
#756954
Filling the groove on the block.
Last edit: 17 Mar 2017 19:17 by SWest.
  • SWest
  • 10 22 2014
17 Mar 2017 19:23
#756955
Took this the other day. One of the bearing journals has a chip out of it. I have the chip and am taking it to Jeff's in the morning. It was from the wreck in 87.
  • SWest
  • 10 22 2014
17 Mar 2017 19:52
#756957
Head cleaned up. About time for paint on the cases and head.
  • missionkz
  • missionkz's Avatar
17 Mar 2017 21:12 - 17 Mar 2017 21:22
#756959
SWest wrote: Filling the groove on the block.
When doing the 1075cc kit last time, I filled mine with Permatex Ultra Black, high temp RTV sealer and used the one piece head gasket. I sprayed the one piece head gasket with the copper coat sealer on both sides, hanging on a coat hanger wire.... and after +4000 miles now.. and finally FOR ONCE, I have put one together that does not leak or seep at all!!!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 17 Mar 2017 21:22 by missionkz.
  • SWest
  • 10 22 2014
17 Mar 2017 21:18
#756960
Glad to hear it.
  • SWest
  • 10 22 2014
18 Mar 2017 13:50
#757009
Took the case to get welded. More clips later.
  • missionkz
18 Mar 2017 18:17
#757062
That looks like a tricky weld repair (without a machine shop line bore of the mains saddle.)
Hope it works out with some relief, to not distort the bearing when it's torqued... etc.
Bruce
1977 KZ1000A1
  • SWest
  • 10 22 2014
18 Mar 2017 19:37
#757073
He's very good. Uploading some clips now. I just put the crank in it spins with no binding.
  • SWest
  • 10 22 2014
18 Mar 2017 20:04
#757075
Here's a clip of the case welding. Took him about two hours.
  • SWest
  • 10 22 2014
18 Mar 2017 21:28
#757084
Looks good. Now to put it together.
  • SWest
  • 10 22 2014
18 Mar 2017 21:38
#757085
I'll take it outside, fill the oil galleys and see how free it moves.
  • spdygon
  • spdygon's Avatar
19 Mar 2017 07:53
#757115
Good stuff Steve....looks like you got it under control.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
