Z2 750 crank (Bossie the Kaw)
Re: Z2 750 crank (Bossie the Kaw)
06 May 2021 07:26
06 May 2021 14:58
Picking up the $75 74 Z1 front end was a good move. Nobody wanted it because it looked so bad.
07 May 2021 07:19
14 May 2021 19:12
15 May 2021 09:13
15 May 2021 09:40 - 15 May 2021 09:53
Steve, both of my 33’s have brass floats. You sure those are ok to run.
EDIT, they measure approximately 30.28mm
EDIT,EDIT; please don’t attempt this at home. Smoking while working around gasoline
Last edit: 15 May 2021 09:53 by Mikaw.
15 May 2021 11:50
They will work but there's a very small window in which to do it as you can see. The brass floats can crack and fill with gas. Common issue with all brass floats. I'll be ordering a set soon.
As for smoking around gas, I grew up around people that did it with no accidents. Just need good ventilation and being careful. I'm not suggesting others do it. It CAN BE DANGEROUS.
15 May 2021 17:21
16 May 2021 06:26
Hard to get them right with these floats.
17 May 2021 07:52
17 May 2021 12:32
Might have to adjust 1&4 on the bike.
18 May 2021 08:21
