- Thank you received: 1
Which KZ750 brake pads will fit the 1985 GPZ750?
- taylee
04 Dec 2014 13:17 #655344
by taylee
1985 GPZ750 (non-turbo)
Which KZ750 brake pads will fit the 1985 GPZ750? was created by taylee
Can someone help with a cross reference on front and rear brake pads for my 1985 GPZ750?
Need to know if either of these will fit my bike:
1983-1984 Kawasaki KZ 750 K1/K2 (LTD)
1980-1983 Kawasaki KZ750 GPz750
1980-1983 Kawasaki KZ750 LTD
1982-1983 Kawasaki KZ750 Spectre
- Thank you received: 2829
04 Dec 2014 14:00 - 04 Dec 2014 14:00 #655354
by 650ed
Replied by 650ed on topic Which KZ750 brake pads will fit the 1985 GPZ750?
No eBay APP ID and/or Cert ID defined in Kunena configurationI recommend you simply get the pads made for your bike rather than trying to do a cross-reference to other models. According to the parts diagrams your 1985 GPZ750 uses part number 43082-1029 for rear pads (see parts diagram below). Here's a set of genuine 43082-1029 pads for $20 delivered on eBay, and that is a great price! Ed
Attachment 00003a_2014-12-04.jpg not found
Attachment 00003b_2014-12-04.jpg not found
Last edit: 04 Dec 2014 14:00 by 650ed.
- Thank you received: 1656
04 Dec 2014 14:18 - 04 Dec 2014 14:34 #655357
by martin_csr
Replied by martin_csr on topic Which KZ750 brake pads will fit the 1985 GPZ750?
From the diagrams at Partzilla, the front & rear brake pads have the same part number.
The cross-reference there lists a number of models that use the same brake pads,
but double-check the info as their x-ref isn't 100% correct:
43082-1029 PAD-ASSY-BRAKE --- 83-85 ZX750-A.
Also some of the following models: ZX550, ZX900, ZN1300, ZG1200, & VN1500.
From the Vesrah site, their part number is: VD-426JL Sintered metal
Vesrah is a Japanese company. ZX750
Last edit: 04 Dec 2014 14:34 by martin_csr.
- zukdave
- Thank you received: 229
04 Dec 2014 17:29 #655368
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic Which KZ750 brake pads will fit the 1985 GPZ750?
No part's swap between KZ and ZX brake's.
I've got both on my bike KZ front and ZX750A1 rear.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- taylee
04 Dec 2014 17:49 #655369
by taylee
Replied by taylee on topic Which KZ750 brake pads will fit the 1985 GPZ750?
Yep you are right. Specific fitment parts are the same price anyways.
