Need a '85 GPZ750 (US model) specific service manu
  • Zephyrrider
  • Zephyrrider's Avatar
Re: Need a '85 GPZ750 (US model) specific service manu
04 Dec 2014 14:03
#655355
I reckon you might be looking at the float valve needle - is it with the float assembly and very small - point on one end and little plunger on other ?
The Jet needle which should have markings on it that you can read is with the top of carb with diaphram assembly and very roughly about 2 inches long.
Mick
1994 ZR750 Zephyr C4.
  • taylee
  • taylee's Avatar Topic Author
04 Dec 2014 14:16
#655356
Yes I know what the jet needled is. :)
There are no markings on the one I was examining.
1985 GPZ750 (non-turbo)
  • Zephyrrider
04 Dec 2014 14:33
#655359
No gunk on it ?
Mick
  • taylee
04 Dec 2014 14:34
#655360
No clean.
BTW Bike Bandit wants $36 for one needle valve and seat!!!
  • Zephyrrider
04 Dec 2014 17:08 - 04 Dec 2014 17:10
#655365
www.pdf-archive.com/2013/01/09/gpz750-full/
Unfortunately this WSM has a pic of a GPZ but is for KZ 750 E1-H1 Models.DL'd it anyway.
Can you change the float seats on your carbs taylee ? Still not sure which part you mean. Was it the jet needle which sits in needle jet (brass cylinder - screws in from below) ?
Mick
Last edit: 04 Dec 2014 17:10 by Zephyrrider.
  • taylee
04 Dec 2014 17:23
#655367
Yes I have the Float Seats and Float Needles both removed.
[IMG
  • Nessism
  • Nessism's Avatar
04 Dec 2014 18:42 - 05 Dec 2014 10:28
#655377
Zephyrrider wrote: www.pdf-archive.com/2013/01/09/gpz750-full/
There is no such thing as a factory Kawasaki GPZ manual. You need the KZ750 manual, and the appropriate supplements which add the GPZ info. The table below shows how the manual structure works. Again, main KZ750 manual, then a supplement for each year.
Mikuni BS CV carb rebuild tutorial here... www.mtsac.edu/~cliff/storage/gs/Mikuni_B...Rebuild_Tutorial.pdf
The proper way to rebuild the carbs involves unganging the carbs. The carb body inconnect tube O-rings are often the ones in the worst condition. It's common to ungang the carbs and have the O-rings crumble in your hands.
[IMG
Last edit: 05 Dec 2014 10:28 by Nessism.
  • Zephyrrider
05 Dec 2014 13:51 - 05 Dec 2014 13:54
#655427
Now i know about GPZ WSM - thanks Nesssim ! : ) .
My float valve seats are pressed in taylee.
$36 sounds ok to me for those parts.
Mick
Last edit: 05 Dec 2014 13:54 by Zephyrrider.
