Winterize 101
Re: Winterize 101
24 Oct 2015 13:28
There's nothing on the forks to lube. I can't imagine what that's about.
Your best bet is NOT to winterize the bike at all. Your best bet is to run it for 10-15 minutes once a week through the winter. This keeps the carbs from getting clogged with fuel gooo; keeps the battery charged; and keeps oil on the cylinder walls. Except for 1 winter I've done this with my KZ650 since it was new and never had any problems starting it when spring came because at most it had only been a week or so since the bike last ran. At the end of the one winter I skipped I had to remove and clean the carbs. Ed
The following user(s) said Thank You: KZam440
- KZB2 650
Re: Winterize 101
24 Oct 2015 13:45
Read so many times that 80 to 90% of engine wear comes from cold starts that I drain the carbs and tank then oil up the cylinders and tank with a mix of wd-40 and oil and keep it wiped down with a little oil to keep the rust away...... tickle the battery for a couple hours with a 1 amp charger every month too.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- KZam440
Re: Winterize 101
24 Oct 2015 14:03
ok thanks, I'll skip that then. I saw it on this:
www.bikebandit.com/community/guides/how-...rize-your-motorcycle
to lube the fork surfaces. I guess I'm good then... we'll see what happens in March
- KZB2 650
Re: Winterize 101
24 Oct 2015 14:09 - 24 Oct 2015 14:10
Wouldn't hurt a bit to wipe down the fork tubes and headlight brackets etc with a shot of wd and oil...... rims, header etc etc.
1978 KZ650 b-2
Last edit: 24 Oct 2015 14:10 by KZB2 650.
- ThatGPzGuy
Re: Winterize 101
25 Oct 2015 05:34
Around here we can buy non ethanol fuel. In the fall I start using that so when I slow my riding down in the winter, there's non-ethanol fuel in the tank. I also do like Ed says and start them up every so often. Oh, and use a battery tender...
Another note on the non-ethanol fuel. I filled up my 400 tank in 2013 with it and was still running off that same tank this year.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
