1981 kz1000...some questions on my bike there
- war113
09 Oct 2014 00:58
Ok so you see this is my kz1000 1981.
I only plastidipped it and made a bit of adjustment.
Questions:
My seat seems odd ....do you think its the original?
2.The PO changed the odo and tach gauges.My tach starts at 6000 rpm but moves up as I rev my bike.My bike revs normaly its the reading thats false.The new tach is not connected by a tach cable to the engine front.Which causes a leak when it spins as there is no cable anymore.Any plug I could put there....homemade or sumthing?.THanks!
Questions:
Re: 1981 kz1000...some questions on my bike there
09 Oct 2014 04:57
That seat has been recovered. The original would have been ribbed. Ed
09 Oct 2014 05:16
Z1Enterprises.com has a tach cable pinion seal & o-ring kit to repair the leak.
Is it a digital tachometer? I'd guess the tach gets it's input from the ignition system... just a guess.
I would try to find a user manual for it --- brand?
Not sure what's meant by it "starts at 6,000 rpm"?
It goes up to 6,000 rpm when the bike is started, but increases above that when revved ???
- war113
09 Oct 2014 19:43
As soon as I start it it goes to 5000...then revs up as normal when engine goes up.
On that photo I just switched the key to ON.The bike isnt event running.
- StreetfighterKz
Re: Re:1981 kz1000...some questions on my bike there
09 Oct 2014 20:19
Is it switched to the "voltage mode" instead of the "tach mode"?
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- Old Rider
09 Oct 2014 20:37
Seat has been recovered for sure, Need to do mine as well. Thats going to be the winter project for me. As the rib's in mine are starting to wear and tear.
Old Dogs never Die.
- war113
15 Oct 2014 04:14
This is my speedo and tach.Its at 5krpm but the bike engine isnt even running.It goes around 6k with the bike on idle.
15 Oct 2014 21:31StreetfighterKz wrote: Is it switched to the "voltage mode" instead of the "tach mode"?
Later, Doug
- war113
18 Oct 2014 01:32
How do you know that....theres no switch or whatsoever..but I think it is as it goes from 5k to 60 with engine turned on..And it moves around 6k depending on the engine rev
18 Oct 2014 05:35war113 wrote: ...kz1000 1981...only plastidipped it and made a bit of adjustment...PO changed the odo and tach gauges.My tach starts at 6000 rpm but moves up as I rev my bike.My bike revs normaly its the reading thats false.The new tach is not connected by a tach cable to the engine front.Which causes a leak when it spins as there is no cable anymore.Any plug I could put there....homemade or sumthing?.THanks!
Click here > tach drive block off plug
18 Oct 2014 05:56 - 18 Oct 2014 06:00
Maybe a 1981 with a 1980 engine?
Could compare serial and frame numbers at www.zedder.com .
At the Zedder site, go to Bike Info.
Last edit: 18 Oct 2014 06:00 by Patton.
18 Oct 2014 06:51war113 wrote: ...theres no switch or whatsoever...but I think it is as it goes from 5k to 60 with engine turned on..And it moves around 6k depending on the engine rev
Kawasaki models originally equipped with the tachometer at hand would be expected to have a means whereby the rider may switch back and forth between the function of rpm and the function of voltmeter.
