Good & Bad about the 1980 Kawasaki 440 ltd
- Moque94331
14 Aug 2014 18:48
Hi all i am new to the site i'm looking to buy a Kawasaki 440 ltd 1980, i'm just wondering the good and bad about the bike and if its a good start up bike. Thanks for any info u can give me.
- !Seymore
- Ride on...
Re: Good & Bad about the 1980 Kawasaki 440 ltd
14 Aug 2014 19:09 - 14 Aug 2014 19:10
Welcome to the site.
If you've never ridden, any smaller bike is a good place to start. Gotta start somewhere. Make sure you take a rider course in your area.
Sorry... I have no experience with the 440, so someone else may have more input for you re: this bike.
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 14 Aug 2014 19:10 by !Seymore.
The following user(s) said Thank You: Moque94331
- azman857
14 Aug 2014 19:23
I did have a KZ440 some years back. Didn't have it long, but I recall it had no vices. It was more of a cruiser than a highway bike. Not to say you can't tour with it, just use the back roads,
15 Aug 2014 05:36
Make sure it has a complete, undamaged airbox. It or the cap are often times missing or damaged.
Replacements, new or used, are very difficult to find for the 440.
The 1980 440 may have points ignition. You could install the electronic ignition from a later model... probably easy to do.
- Moque94331
15 Aug 2014 12:45
Thanks for the info, but is it a good start up bike.
- Tyler
23 Aug 2014 14:34
The 440 is a good beginner bike. It has a low seat, and easy to drive. It has enough power to run on the highway, but it's not the best at that. As an in town commuter it is a great little bike.The engine is well built and has few problems. As mentioned above make sure the airbox and airfilter have not been messed with. As with any old bike make sure of the condition its in. Check the tires for weather cracking and make sure the front brake feels firm. It should start easily and need some choke to idle when its cold.
"74 Yamaha DT 400 Enduro
