Motorcycles with Automatic Transmission?
  • happyhunter
  • happyhunter's Avatar Topic Author
10 Aug 2014 18:09
#643382
So I've got about 1000 miles on my first motorcycle, a 1982 305 CSR. I am liking it. However, I have tendonitis and my left arm is starting to have problems. I have not done anything unusual with my left arm so I am left to suspect it may be the clutch (even though the 305 has a very light clutch).
I seem to remember back in the early 80s that there was a Kawasaki that had an auto trans. I think it was the 440 LTD. What model of old Kawasaki had an auto trans option? What kind of reputation does the auto trans have?
Thanks,
HH
'82 Kawasaki KZ305CSR
I did not set out to buy a project bike,
but I got one anyway.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Motorcycles with Automatic Transmission?
10 Aug 2014 18:25 - 10 Aug 2014 18:29
#643390
Last edit: 10 Aug 2014 18:29 by 4TheKZ1000.
  • nickleo373
  • nickleo373's Avatar
10 Aug 2014 18:37
#643394
The hondamatics are supposed to be good automatic motorcycles. I've never personally rode one but I've heard good things
1981 KZ550C LTD
"If you ain't first, you're last"
  • wireman
  • wireman's Avatar
10 Aug 2014 19:20
#643405
Try adjusting the clutch ;)
10 Aug 2014 19:51
#643410
Once underway, it's okay to shift without using the clutch.
Good Fortune! :)
The following user(s) said Thank You: wireman, Tomolu5
  • azman857
  • azman857's Avatar
10 Aug 2014 20:06
#643415
Honda made a 750 and a 450 cc Hondamatics . 2 speeds if I recall correctly.
  • wireman
  • wireman's Avatar
10 Aug 2014 20:23
#643418
azman857 wrote: Honda made a 750 and a 450 cc Hondamatics . 2 speeds if I recall correctly.
One of many Hondas that Dale Walker kicked ass on back in the day! :laugh:
  • Tomolu5
  • Tomolu5's Avatar
10 Aug 2014 20:38
#643419
Patton wrote: Once underway, it's okay to shift without using the clutch.
Good Fortune! :)
+1 here, I normally use it on my kz, but my gsxr wouldn't know what to do if I clutched between gears.
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
  • RonKZ650
  • RonKZ650's Avatar
11 Aug 2014 19:14
#643548
The newer motorcycles with a dual clutch transmission, which I guess is more or less an automatic and manual in one seem pretty neat, as used in older FJR yamaha, and the Honda VFR1200 among others. As to automatic back in the old 1978 time frame, they were pretty crude. I remember a test of the honda CB750 in standard and automatic in a comparison. The standard was around a 13 second quarter mile at 100mph give or take, the Hondamatic was around 17 seconds and don't remember the speed, but if it goes in sync with the time it would be like 70mph. Of course speed is not everything. The first cars with automatic in the early 50s suffered dramatically in acceleration vs the manuals of the time. With time a modern automatic will run with a manual after all the technology advances of 60yrs in cars. A 1978 motorcycle with an automatic is going to be pretty antiquated to say the least if it works at all, which is always a question with any automatic.
  • seanbarney41
  • seanbarney41's Avatar
  • '79 kz1000 LTD '75 Honda CB750
11 Aug 2014 19:54
#643559
There is a healthy crew of guys over at sohc4.net that are bracket racing 750 automatics. They have one deep in the 11's and it's pretty damn consistent.
The following user(s) said Thank You: PLUMMEN
  • PLUMMEN
  • PLUMMEN's Avatar
11 Aug 2014 20:14
#643564
Dale walkers rides back in the 70s,the guy could put a mped into the 12s if he wanted to bad enough! :laugh:
  • happyhunter
15 Aug 2014 18:57
#644125
Good Fortune! :)
Patton,
wow neat. I looked it up on youtube a couple days a go. I rode the 305 to work today. It was pretty easy to upshift but it wasn't too long before I was downshifting too. On the way home I hardly touched the clutch. Only used it to stop and go. I usually use it to upshift first to second just because I am too impatient and like to accelerate. But overall going clutchless is a big boon for me.
Thanks,
HH
