Is a GT a KZ or completely different?
- TheForumTroll
22 Jul 2014 08:10
I'm confused and Google didn't make it any better. My girlfriend is looking at a Kawasaki GT550 and it looks like a KZ to my new-to-kz eyes on the picture she's shown me. Are they different? It's a GT550 (says so on the bike), not a Z 550GT.
If they are indeed different, any info on it compared to a KZ?
-[ KZ700-A1 '84 ]-
- bassie10
Re: Is a GT a KZ or completely different?
22 Jul 2014 08:27 - 22 Jul 2014 09:31
I own a beautifull GT750
GT750 and GT550 is just another name for Z750GT and z550GT, just google the pics.
you have to like the looks, I do, and they wil never brake down on you, they are super reliable bikes..
Last edit: 22 Jul 2014 09:31 by bassie10.
- TheForumTroll
22 Jul 2014 08:39
Ah, I thought they looked the same! So what is the difference between a Z 550 GT and a non-GT? The shaft drive?
I know it is great bikes. I own a 700 myself (:
-[ KZ700-A1 '84 ]-
- bassie10
22 Jul 2014 09:36
In my opinion the gt's are very different from the rest, not many of the parts are interchangeble...
from the factory they have air suspension in the back, and air supported suspension in the front and ofcourse the shaft drive.
- TheForumTroll
22 Jul 2014 12:30 - 22 Jul 2014 12:45
An air supported suspension? Is that a normal suspension (spring in oil) with air vent in? Because the normal KZ has those too.
I'll look for a service manual or at Kawasaki. Interesting what differences there are.
Edit: So I found some more info.
"1982 Kawasaki Z750GT (Europe)
Touring was being quite the craze and riders wanted to see the sights on bikes. With Kawasaki introducing shaft drive to it's touring models like the Z1000, Z1100ST and Z1300, the new Z750GT extended the sports tourer shaft drive lineup.
The Z750GT was derived from the Z750E model with a revised engine and dual overhead camshafts that contributed to a healthy 78 hp @ 9500rpm. Forks were air-assisted shocks and had progressive action but could be easily load adjusted. Engine was rubber mounted and an oil cooler helped to promote moderate engine temperatures under long range loads. Kawasaki even included a large tank, shaft drive and comfortable bench seat.
1983 Kawasaki Z550GT (Europe)
After positive sales experiences with the Z750GT; Kawasaki increased their tourer line with a new 554cc based on the proven Z550 reliable four-cylinder engine with an oil cooler producing 50 hp @ 8500 rpm with a shorter final drive ratio for more toque and a shaft final drive. Using two air-assisted spring front fork legs together with a fill valve the suspension adjusted to different loads much better."
-[ KZ700-A1 '84 ]-
Last edit: 22 Jul 2014 12:45 by TheForumTroll.
- zukdave
24 Jul 2014 17:51
Kaw. only used the KZ name in the USA rest of the world they were just Z's,
K.Z. was a Natzi prison camp name didn't go over well in Europe.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
