- Thank you received: 133
What causes uneven tire wear?
- Topper
03 Apr 2014 09:14 #627671
by Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
What causes uneven tire wear? was created by Topper
I've noticed my KZ750 really goes through rear tires. The most recent tire is a Conti Twin K112 4.00-18. It's not exactly a budget tire, but after 3,000 miles it's already pretty shot.
The wear on the tire is pretty uneven and I'm wondering if there's something else going on that might be causing my bike to eat rear tires.
The tire has a center groove running all the way around the circumference of the tire. In some sections there's a fair amount of tread left on that center groove, I can see the wear bars and still have a bit to go before I reach them. In other sections of the tire though, the groove is gone, the wear bars have vanished and the tire is slick.
Is this a normal way for a tire to wear? I would think it would wear the same all the way around. It's not like I ride on one part of the tire more than others.
Would this happen if the tire wasn't properly balanced? I haven't noticed anything in riding the bike that makes me think the wheel's out of balance. It vibrates just about as much as a parallel twin tends to do.
1979 KZ750 Twin
- Thank you received: 2829
03 Apr 2014 09:43 #627675
by 650ed
Replied by 650ed on topic What causes uneven tire wear?
If that's the only tire that has worn unevenly, it could just be a bad tire or possibly the tire was out of balance. If the problem has happened on other rear tires it is possible that your wheel is out of round. You may want to use a dial gauge to check the rim for roundness. Ed
- Topper
03 Apr 2014 09:49 #627677
by Topper
1979 KZ750 Twin
Replied by Topper on topic What causes uneven tire wear?
I think the last rear tire suffered similarly uneven wear.
1979 KZ750 Twin
