Swinging arm bolt dia 79 KZ1000 LTD?
- richard_oxon
25 Mar 2014 19:43 - 25 Mar 2014 19:50
Hi all my bikes in storage at the mo , but i need to know the swinging arm bolt dia . its a 79 kz1000 ltd . trying to get my gsxr srad swinging arm top hats and stuff made . if you could help out many thanks
** KZ1000 B3 1979 ** 1015cc wiseco pistons 33 smoothbores ported head 410 cams
** KZ1000 A1 1977** 1075 wiseco pistons 438 megacycle cams ported head rs34 flat slides
Last edit: 25 Mar 2014 19:50 by KZQ. Reason: Original title not descriptive
Re: Swinging arm bolt dia 79 KZ1000 LTD?
26 Mar 2014 06:11
my experience says they are usually right at .628 but i have gotten to where i have the bolt that is going to be used to measure for sure,because a couple thousandths right there can sure make a difference in how it feels back at the axle.
hth,
hth,
The following user(s) said Thank You: richard_oxon
- richard_oxon
26 Mar 2014 07:57
Many Thanks leon
its been slow goin so far but getting there .
- pete greek1
26 Mar 2014 09:41 - 26 Mar 2014 09:42
don't know if this helps, or not ...Pete
Last edit: 26 Mar 2014 09:42 by pete greek1.
26 Mar 2014 12:06richard_oxon wrote: Many Thanks leonits been slow goin so far but getting there .
steady on sir!
you are closer than you was !!!!!
