- Thank you received: 1
1975 Z1B need help to verify
- JPK455
21 Mar 2014 19:41 #626100
by JPK455
1975 Z1B need help to verify was created by JPK455
Hi I am new to the forum and am looking for some help I have come across a 1975 Z1B 900 bike I am looking at buying and need some help to make sense of it. The frame number is Z!F-75194 engine is Z1E-080735 but the bike is painted like a 1973 Z1 Root beer and Orange the engine is black I have attached the photo from the add. The person selling it is the daughter of the owner. What I am asking is how much is it worth?. And did they have this colour for a 1975 all the research that I have found is that this is a 1973 colour scheme only. I did not have my camera when looking at bike I can go back and take more pictures if needed. I am thinking value around 6500.00 what do you guys think. Engine has also just been rebuilt has about 500 miles on it and the pipes are period correct and are like brand new, the rotor is about the only piece besides the paint that may not be correct. your help is very much appreciated.
Attachment _20.jpg not found
- Thank you received: 2098
21 Mar 2014 20:01 - 21 Mar 2014 20:02 #626102
by Patton
Replied by Patton on topic 1975 Z1B need help to verify
Handsome bike.
Looks like 1973 body parts (tank, side covers and duck tail) were put on the 1975 model.
Perhaps the engine was painted when rebuilt.
Last edit: 21 Mar 2014 20:02 by Patton.
21 Mar 2014 20:07 #626103
by Patton
If carbs have top caps with three screws, they are 1976 or later carbs.
21 Mar 2014 20:12 - 21 Mar 2014 20:18 #626105
by Patton
It's also possible that a 1973 cylinder block and valve cover were installed on the 1975 engine, perhaps incident to the rebuild.
Last edit: 21 Mar 2014 20:18 by Patton.
- Mcdroid
- Gone Kwackers
- Thank you received: 316
22 Mar 2014 02:11 #626113
by Mcdroid
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Replied by Mcdroid on topic 1975 Z1B need help to verify
The motorcycle is definitely a 1975 Z1B based on both engine and frame VINs. But it is cleverly disguised as a 1973 Z1...and some might find that appealing. I'm more of a purist. That aside, if you have transcribed the VIN's correctly, then the engine cases have likely been replaced somewhere in the life of the motorcycle. The trick in deciding if a Z1 has 'matching' engine/frame VIN, is that the two numbers are within 400 or less of each in other. The numbers you provided are several thousand apart. This would not have happened at the factory. So, this information is a strong negotiating point...$6500 is probably not a bad amount, bearing in mind that a Z1B with matching numbers would bring $10,000 or more and a real Z1 might bring $15,000 or more. You also might run all this by the fellows at
www.Kawasaki-Z-Classik.com
to get an even more opinionated view (some of the best Z-geeks on the planet live at that site).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
The following user(s) said Thank You: Patton
22 Mar 2014 04:03 #626116
by Patton
Thanks, Mcdroid!
Mcdroid wrote: ... The trick in deciding if a Z1 has 'matching' engine/frame VIN, is that the two numbers are within 400 or less of each in other....
Thanks, Mcdroid!
- JPK455
22 Mar 2014 05:31 #626124
by JPK455
Replied by JPK455 on topic 1975 Z1B need help to verify
Thank-you for the info it is very much appreciated.
