- Thank you received: 1
Where bike was made
- NHenneous
16 Mar 2014 17:02 #625464
by NHenneous
NHenneous
Where bike was made was created by NHenneous
Hi guys I have a 76 kz900. Been trying to locate where bike was made and if engine is correct. Vin is Z1F508705 engine is Z1E103711. I have looked at some sites they either say no none match or bike was made in Europe but no details. Thank you in advance for any help.
NHenneous
- Nebr_Rex
- Thank you received: 299
16 Mar 2014 17:40 #625468
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Where bike was made
I thought the bikes were either manufactured in Japan or assembled here in Lincoln.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- NHenneous
- Thank you received: 2098
17 Mar 2014 01:38 - 17 Mar 2014 10:32 #625507
by Patton
Replied by Patton on topic Where bike was made
Per
www.zedder.com
Engine made in Japan, and frame made in USA. The numbers are correct.
Last edit: 17 Mar 2014 10:32 by Patton.
- NHenneous
- zukdave
- Thank you received: 229
17 Mar 2014 04:13 #625513
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic Where bike was made
VIN. number's starting with a 5 are Lincoln built bike's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Thank you received: 1656
17 Mar 2014 05:55 - 17 Mar 2014 05:56 #625517
by martin_csr
Replied by martin_csr on topic Where bike was made
The label doesn't indicate the place of manufacture?
From the info at Zedder.com for the 76 A4 the bike appears to be a USA model.
Frame No. Range --- Japan MFR Z1F-085701 - 117060
Frame No. Range --- USA MFR Z1F-500001 - 510340
Last edit: 17 Mar 2014 05:56 by martin_csr.
17 Mar 2014 10:27 - 17 Mar 2014 10:28 #625542
by Patton
Last edit: 17 Mar 2014 10:28 by Patton.
- zukdave
19 Mar 2014 20:04 #625844
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
I think it was an across the board thing with Kaw.
all bike's built in the USA vin. started with a 5. best I know.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
