blasted, cleaned, studs installed
- LarryC
21 Feb 2014 16:55 - 21 Feb 2014 18:14 #622970
by LarryC
Larry C.
blasted, cleaned, studs installed was created by LarryC
77 KZ1000 cases
Attachment PART_1393021545149.jpg not found
Attachment PART_1393000402635.jpg not found
Larry C.
Last edit: 21 Feb 2014 18:14 by LarryC.
- tomsbadkz
- Thank you received: 44
21 Feb 2014 19:31 #622978
by tomsbadkz
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
Bored throttle bodies
Replied by tomsbadkz on topic blasted, cleaned, studs installed
Larry, is that soda blasted or glass bead blasted and did you spray them to seal them? thanks. tom
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
1984 GPZ1100
Cavanaugh Head
1170cc
Web 415 cams
RC Hp Inj.
- LarryC
22 Feb 2014 04:28 #622984
by LarryC
Glass. The don't need to be sealed.
Larry C.
Replied by LarryC on topic blasted, cleaned, studs installed
tomsbadkz wrote: Larry, is that soda blasted or glass bead blasted and did you spray them to seal them? thanks. tom
Larry C.
- bluej58
- Thank you received: 511
22 Feb 2014 09:13 #623001
by bluej58
78 KZ1000 A2A
Replied by bluej58 on topic blasted, cleaned, studs installed
Very nice looking Larry.
78 KZ1000 A2A
- peter1958
- Banned
- Thank you received: 198
22 Feb 2014 14:56 #623023
by peter1958
Replied by peter1958 on topic blasted, cleaned, studs installed
Very nice as usual. Some day i will ride down there and drop a bike off. sit at local still and drink till its done!
- bluej58
24 Feb 2014 03:57 #623155
by bluej58
78 KZ1000 A2A
78 KZ1000 A2A
- LarryC
24 Feb 2014 04:03 - 24 Feb 2014 04:17 #623156
by LarryC
Larry C.
OMR did a nice job on his with nylon brushes and a drill. There's more than one way to accomplish any task
Here's the bottom end assembled.
Attachment PART_1393095603810.jpg not found
Larry C.
Last edit: 24 Feb 2014 04:17 by LarryC.
- 74ullc
- Thank you received: 23
03 Mar 2014 19:17 #624085
by 74ullc
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
Replied by 74ullc on topic blasted, cleaned, studs installed
Those parts look really good!
If its not a secret, what type/brand/size/mesh of bead are you using? I tried glass beads on a scrap piece of cast and it seemed to want to smear the aluminum around, if that makes sense. It came out clean but I didn't like that it was moving the aluminum around. I'm not sure what size the beads were, it was given to me in a coffee can to try out, but it sure looked very fine.
I have a bag of Clemtex glass bead size MS-MH that the guy gave me when I bought the cabinet from him (Econline) but I haven't opened the bag to see what it even looks like.
I just bought a few bags of 120 mesh garnet. So far loving it (clean, fast, very low dust) but not sure how it would be on aluminum. Thinking too aggressive.
Gulf Coast, Texas
1977 KZ1000LTD
1984 VF700F
