Tire series size questions...
  • Serpent7
  • Serpent7's Avatar Topic Author
  • Nothing professionally, only for fun...
13 Jan 2014 11:32
#618447
What are the advantages, and dis-advantages from changing the series tire sizes on a 79 kz1000? Will my top speed decrease? Will my gas mileage decrease? Are there any advantages except looks?
current size: (front) 110/90/19, (rear) 130/90/17
new tire size: (front) 110/80/19, (rear) 130/80/17
19 Audi Q5
14 Volkswagen Touareg X
97 Honda Shadow Spirit
79 Kawasaki KZ1000 st
79 Volkswagen Transporter
73 Volkswagen Thing
Re: Tire series size questions...
13 Jan 2014 15:41
#618473
80 series tires of the same width are smaller in diameter than 90 series tires. Your fuel economy will decrease because the smaller diameter tires will need to turn faster for the bike to run a given speed which will increase the engine rpm for that speed. Also, your top speed will decrease. Your speedometer error will increase as it will show you traveling faster than you really are. This problem already exists with most KZ speedos, but the smaller diameter tires will make it worse. Ed
  • Serpent7
14 Jan 2014 05:57
#618530
650ed wrote: 80 series tires of the same width are smaller in diameter than 90 series tires. Your fuel economy will decrease because the smaller diameter tires will need to turn faster for the bike to run a given speed which will increase the engine rpm for that speed. Also, your top speed will decrease. Your speedometer error will increase as it will show you traveling faster than you really are. This problem already exists with most KZ speedos, but the smaller diameter tires will make it worse. Ed
Very good info… Any advantages?
19 Audi Q5
73 Volkswagen Thing
