- Thank you received: 288
A little Observation!
- les holt
I had a conversation with Jeff Saunders at the Mid Ohio Vintage Bike Days about his turbo. It revolved somewhat around the resto or rebuild talking about the rake. He was kind of wishing it hadn't been raked and I understood why he felt that way, it took away from it's originality.
So, here is my take after thinking about it, and I thought about it a lot!!
Had they not modded the motor, someone who modded their cb750 would have waxed our ass and the old Kaw would have been labeled a pig!
Had someone not raked an old Kaw, we wouldn't have a clue just how fast it was capable of being! Trust me, this is a true statement!!
Had someone not painted it with a wild 70's scheme, we wouldn't have been noticed in a show till now, and that would be only for originality.
Had we not have played with it, Jeff from Z1E, Jay from KZZone wouldn't have the jobs they do now!
The public's personal expressions on their precious baby's, their little girl, what ever they called that 2 wheeled beast that they skipped a mortgage payment on so they could put a Denco Pipe on or a set of Mikuni smooths on so they would be the king for a while is what has made the Kawaski KZ or Z1 what it is today!! So, the next time you come across an old Kaw that has been raked, stretched, slammed, turbo'd, shaved, painted, or for a lack of words, raped! Look at it as a contributor to the heritage. Not every manufacture has a model that is so sought after as the Z1 has become by it's own designers and it has a reason!
FYI, Just food for thought.
Les Holt
- rstnick
- Thank you received: 377
A few years later, and new model was designed, fixing some of the short comings of the early Zs.
The 1977 KZ650.
About the size of a 550, and the power of a 750,
In it's day it beat out most if not all 750s.
"The KZ900 & KZ1000 models were faster than the KZ650, but not more reliable, and their frames were inadequate for their power leading to handling issues. Their pressed together crankshafts sometimes twist and cause serious problems, so their owners often have the crankshaft removed and welded to prevent the twisting. The KZ650 has a better frame, a one piece crankshaft, and overall is a better bike. It was designed after the Z1 / KZ900 was in production, so the lessons learned from those production bikes taught Kawasaki what mistakes to avoid when building the KZ650." Ed
"The 650 engine, in my view as a mechanical engineer, is the superior engine. One piece crank, plain bearings, under bucket shims, etc."
"Gyoichi Ben Inamura was the head designer of the original Z1 in 1973... the 1000 is a bored out version of the 900 motor, identical in every respect. The same design team was used on the 650 in 1977 - I doubt they went backwards at that point and in fact a lot of lessons learned from the Z1 made it into the design of the 650 as improvements - how could the 650 ever be considered a inferior machine as compared to a 1000?
If you look at a 1977 650 and the same year 1000 (first year) they looked pretty similar except the 1000 was a lot bigger (heavier) and faster because of the larger displacement... this however did not make it a better motorcycle."
"The 650's are a better bike in my own opinion , when they came out they were the fastest 750 that year but also beat the 1000 in 24 hours of continues riding. My hopped up 650 also takes 1000's in a straight line too, at the race track I'd kill my friends by 1/2 second every time on their 1000's.
Mark"
The 650 set many 1977 AMA/FIM 750cc records, not beaten until the GSXR750 came out in '85 (I've heard).
The 650 never did get the same following as the Z1s/kz1000s, which I guess is good for the 650 owners, as prices for parts have not gone up like the big KZs.
A little while back, kawi//twin went to the ROK (Rider's of Kawasaki) Owners Club Koffe Meet at Kawasaki's USA Headquarters.
Here's are his words:
Yesterday I went to Kawasaki's USA Headquarters in Irvine, California, about 40 miles from my house. ROK (Rider's of Kawasaki - Kawasaki owners group) was having their 1st Kawasaki Koffe Meet. Great fun and met and talked with some interesting people.
The most interesting person I met that morning was Martin Carney who I believe was from England, but don't hold me to it. I am not great with accents . He was a tech/mechanic with Kawasaki back in the 70's and was instrumental in building up the engine side of the 3 1977 KZ650's for the 24 Hour record in the 750cc class. He said that the only changes to the stock bike were these:
1) Wider rims on Goodyear slicks, but laced to the stock hubs
2) Custom rear shocks
3) Customized gas tank to hold 2 more gallons
4) Bottom end of engine remained untouched, but received custom cams and larger valves
5) Carbs used were from a Z1 even though the pics show stock carbs
6) Points and Ignition remained stock
7) Custom rear sprocket. I did not count the teeth.
Exhaust is straight through, no baffles. Custom to look like stock.
9) Lockhart oil cooler from a period Triumph.
10) Airbox was empty with no filter and modified carb hoses to connect the Z1 carbs to the KZ650 airbox
Anyways he was a fountain of information. He retired 4 years ago, but Kawasaki keeps calling him back to work on "special projects". EVERYONE seemed to know him. I talked to him for a good hour as I have a '78 KZ650 and he loved talking to me about the racers involved in the record run. He told me how stone reliable this and other Kawasaki motors were. Good fun. Here is a picture of him next to the only remaining survivor of the 3 record bikes that Kawasaki knows of. He said that one was dismantled and the other sold very early on after the record was smashed to a collector.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- rstnick
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- RonKZ650
- Thank you received: 240
Really if you put a 1977 Kz1000 and a 1977 KZ650 side by side and had to pick one it would depend on what you want to do, long distance and long life the Kz1000 hands down. Short distance, commutes to work, possible a little more aggressive twisty roads, the KZ650. KZ1000 will outlast the KZ650 engine in stock form. Just my own opinion of course, but have ridden both a lot.
- Mcdroid
- Gone Kwackers
- Thank you received: 316
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Jeff.Saunders
The CB750 put a reliable and decently fast motorcycle in the hands of the average person. No longer did you need to be a mechanic to own a motorcycle. No longer did you endure the puddles of oil under the British bikes and Harleys.
The Z1 turned the motorcycle into a performance machine. The CB750 was civilized, but uninspiring to ride. The Z1 was fast. Not just fast, but over-engineered massively. The first few performance tuners paved the way for many to follow. The handful of companies like Yoshimura and RC Engineering grew in a long list making and marketing parts. The drag strip and race track were showcases to the power these bikes could deliver.
Certainly back in the 70's, nearly everyone I knew who had a Z1 wanted it to go even faster. Customizing was the 'in' thing. From Amen Savior choppers to café racers like the Rickman, everything was about customizing. Repaints, 4-1's, pistons, cams, - and a fair share of ugly fairings and seats - all very normal back then. Even the automotive industry took note with companies like Crane making cams.
The business casualties are many. Very few of the performance and aftermarket companies from back then survived to current. Jay's APE is one, V&H was spawned from RC Engineering, but many of the names from back then are long gone...
Times change... I like the stock Z1's - but I do appreciate the custom bikes too. The funny thing is the USA and much of Europe are more into the showroom condition bikes than Japan. When you look at Z1 pictures out of Japan, you rarely see a stock looking bike. They are all tweaked in some form - many radically. Turning the Z1 into art seems to be the current Japanese thing.
www.z1enterprises.com
Z1 Ent on Facebook,
- Kidkawie
- I bleed premix
- Thank you received: 245
Jeff.Saunders wrote: No longer did you endure the puddles of oil under the British bikes and Harleys.
stator grommet..... :whistle:
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
- Jeff.Saunders
Ron nailed that one. 40 year old rubber is 40 year old shrunken and dried out rubber.... I must admit, the vast majority of my Z1's have leaked there - but it's not the puddles of oil you used to get under BSA's and Triumph's....
Z1 Ent on Facebook,
- koolaid_kid
- Thank you received: 99
I never did figure out why they thought vertically split crankcases were a good idea. Or why they did not rectify their mistake. Of course, Lucas electrics and Amal carbs also helped their reputation. I rode with a Bonneville in the late sixties, and I was always tickled to see him "tickle" the carbs before he jumped on the kickstarter.Jeff.Saunders wrote:
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- les holt
Les Holt!
- Intrepid
I bought my KZ900 new back in 76 and quickly grew to love it as it came straight out of the box. Didn't change a thing until the warranty ran out. After that, like a lot of guys back then, I started to make changes as soon as I could afford them. Something about having so much of that "Get Up And Go" feeling really worked on me. Just owning a Z, in those days, meant you were on Quicksilver with not a lot of competition. And the basic model Z had a great deal of possibilities and made a pretty good platform on which to build and modify the machine to the individual needs or wants of the rider. The sky seemed the limit.
Stock or modified, city street, freeway or drag-strip, in my mind they all have a solid place in the world of motorcycles. I've always enjoyed seeing where the craft goes. There are a lot of bright and talented people out there doing some pretty cool stuff. I wouldn't be surprised to hear that someone has built an Off Road version. Who knows; maybe out there somewhere is an In-Line 4 lurking in the bush just waiting for some unsuspecting Taco or Husky to go buzzing by. And Hill Climbing? Think of the amount of dirt a machine like that could throw.
Riders have always been a kind of R&D for the manufactures. Each change a rider makes adds to the body of knowledge and effects the models that come down the line in future years. Even the Stock machine tells a story as the years pass and broaden the field. Every since the In-Line 4 was introduced, the world of motorcycles has gone through rapid growth and change. And whether the change has come by way of the guy on the street working to add a few horsepower or make the bike handle better in the curves, or the Company filling the needs in the market place called for by the rider; it's a good time for Bikes.
It's said that one can tell a tree by it's fruit. Judging from what I've seen in the gallery and the posts, plus my own time with a KZ900, I understand why the Z and it's generation is so prized.
Peace, Good Health and No Speed Limit To All, Intrepid
