Calling All KZ Guru's.....
- NakedFun
20 Nov 2013 14:24
Just checking my sanity. Did Kawasaki ever release, in the United States, a KZ750 Twin with shaft drive? If not, has anyone seen or done a KZ750B shaft drive conversion? Would the apporpriate internal output shaft and drums, swap into a KZ750B case and allow the bevel drive to bolt on? Any information would be appreciated.
Cory
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
1976 Kawasaki KZ900
- Mcdroid
- Gone Kwackers
Re: Calling All KZ Guru's.....
20 Nov 2013 15:56
The short answer is no. The closest Kawasaki came was the 1983/84 750K model which a vertical twin with a belt drive. There technically were 750 shafts in the mid 1980's but they were the VN series which were V-twin Vulcans but the transmission design is radically different from the vertical twins.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- guitargeek
20 Nov 2013 16:22
Anything can be made to fit into anything else, if you have the time, money, resources and energy to make it happen.
I'd ask Steell, he knows a lot about 750 twins...
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- Nebr_Rex
20 Nov 2013 17:44
Doesn't the 750b and 650/750-4 use the same case cover behind the counter sprocket?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- steell
21 Nov 2013 20:15 - 21 Nov 2013 20:15Nebr_Rex wrote: Doesn't the 750b and 650/750-4 use the same case cover behind the counter sprocket?.
And the 550/900/1000/ and probably 1100.
Check the parts diagram at kawasaki.com and see if you can find a chain drive bike that uses the same output shaft as the 750 twin. Then look for the shaft drive output shaft for the same bike.
I don't think there are any.
Last edit: 21 Nov 2013 20:15 by steell.
